what should I do that I could get my car to run as well as possible with these parts?
70 block .060 over. piston 1mm below deck level.
metal cover seals. pressure 10.3.
516 covers.
440 sixpack standard size valves.
a little less than two-inch sheet metal manifolds.
original 3xholley in vacuum
original current separator, the centrifugal advance off.
original stall speed
3.55 sure grip.
when you weigh 40 mail in the bottom of the gas, so it knocks a moment and then starts to run.
Bensin 98 oct pump gas.
camshaft 292 hemi purple saft
already works fairly well, not be interrupted, etc.
thanks, ben
![](/ubbthreads/images/graemlins/beer.gif)
