long time to get oil pressure #1386729
02/13/13 01:32 AM
02/13/13 01:32 AM
Mb Can
demonstrator Offline OP
Mb Can
I have a 420 small block that when ever it sits over night or longer it takes 15 to 30 seconds to register oil press.The line that goes to the guage is AN4.Using Wix 51515r filter.Any ideas guys?
Re: long time to get oil pressure [Re: demonstrator] #1386730
02/13/13 02:37 AM
02/13/13 02:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you using a remote filter on it... if so .. its
draining back down
Re: long time to get oil pressure [Re: MR_P_BODY] #1386731
02/13/13 02:44 AM
02/13/13 02:44 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
air in the psi guage line might be some of the prob.mine took five seconds to get full oil pressure acording to the guage in my boat, the Racepak told a much different story. (one point six seconds)
Re: long time to get oil pressure [Re: MR_P_BODY] #1386732
02/13/13 05:12 AM
02/13/13 05:12 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
another reason to use an accumulator
home of the
Sox and Martin Hemi Duster
Re: long time to get oil pressure [Re: HEMIFRED] #1386733
02/13/13 09:44 AM
02/13/13 09:44 AM
maryland
74yellowduster Offline
maryland
does the engine have a lot of miles?
if it's an old oil pump, you might want to pull it. pull the oil pan as well and make sure the pickup is not half plugged up with gump.
if it's a fairly new engine, you should still check out the oil pump. sometimes the spring in the pump can be defective, or not seated right etc.
better safe than sorry.
Re: long time to get oil pressure [Re: demonstrator] #1386734
02/13/13 10:33 AM
02/13/13 10:33 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO it's because of the #4 line, you would have quicker response with #3 line, no worries.
