I already built that motor
![](/ubbthreads/images/graemlins/laugh2.gif)
I bought my block new from a Dodge dealer when thy were still avail.....
I had Jeff at Modern do my heads.
No need for a .700 lift cam or aftermarket rockers. These motors will spin 8k all the time with out breaking a rocker.
Buy the hardened shafts and hold downs that tie the intake and exhuast shafts together with the ARP bolts. The stock hold downs are chincy.
You will not be running much spring PSI about 150-180 to 300 open.
Dave Weber is really good with the 3G HEMI stuff his shop is called Modern Muscle. He supplies Mancini with all there 3G stuff. Moparts member Gemlin Steve helped me alot in building my motor.
I had NO luck with INDY but I built my motor PRE Josh. They only wanted to send me a catalog
![](/ubbthreads/images/graemlins/hammer.gif)
I would only ask for Josh If you call INDY
