6.358 rods with 1.094 pins Question?
#1386616
02/12/13 10:11 PM
02/12/13 10:11 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Can Anyone advise from experience I have a set of eagle H beams for a stroker 451 project that the machine shop bored out the 9.90 bushings to 1.094 Is this safe to run? are there any reasons why i should not? Thanks
1969 Dodge Charger
1969 Dodge Superbee
Re: 6.358 rods with 1.094 pins Question?
[Re: dogdays]
#1386622
02/13/13 07:11 PM
02/13/13 07:11 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Really. I looked in their online catalog this morning and couldn't find any 6.358" rod. However, it wouldn't be the first time that an online catalog was missing something. R.
They may have discontinued them because they don't get used much .
[Re: JohnRR]
#1386623
02/13/13 10:27 PM
02/13/13 10:27 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
The first question is why are you building a stroker with that short rod ? Part of the advantage of the stroker is shorter pistons so the engine revs faster.
That said , how much material is left on the rod without the bushing and how much did he remove ?
Well its a long story but it turns out it was the only way to use a set of 800 dollars set of ross full floating pistons that i had on the shelf from a mistake made on a stroker kit that i had to re order the pistons because some one orderd .990 pins and 1.094 custom pistons.
So instead of 8 Christmas presents for my buddies as ash trays , I don't think i have 8 buddies who smoke lol. I figured out a 1.73 comp height with 3.75 crank i had sitting on the shelf. Would fit into a 50k mile 400 block that i had by honing it to size .010 over i could make 450 cubes with the .030 rb pistons laying around with stock 6.358 rod length. the combo works out pretty close to zero deck. I could not find them on the internet either but i found these today http://www.spiderautomotive.com/crs6358c3d.html This is the part i have it just looks like the bushing for the rod is pretty thin, that is why i am concerned i thought the machine shop bored the .990 pins hole to fit 1.094. but since i did find a set i guess they make um..... but worried about durability!
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#1386624
02/13/13 11:49 PM
02/13/13 11:49 PM
JohnRR
U.S.S.A.
Gotcha and I know how it is to have a set of custom $1000 paperweights that you need to make work I can't remember if the eagles I have in my 383 are .990 or .1094 , I'd would think the rod blanks are the same and the finish hole size is different depending on the bushing. If the guy that did the rods just honed it out to 1.094 did it so it was either a press fit or to floating without a bushing you should be fine .
