Re: Valve train question [Re: bobs66440] #1385420
02/15/13 01:32 AM
02/15/13 01:32 AM
Dallas, Texas
bigcountry Offline OP
Dallas, Texas
Thanks for all the reply's. Plan on putting a new set of lifters in it and give it a go. Might buy a new set of heads for it this summer and if I do I will go with an adjustable roller rocker setup.
Re: Valve train question [Re: bigcountry] #1385421
02/15/13 07:19 AM
02/15/13 07:19 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you aren't going to use a big cam with high spring pressure with a tendency for side loads, rollers are a waste of money. Get a set of doctile adjustable rockers or leave well enough alone. for a street engine you will likely notice very little difference in the ratio difference in the OEM and the more accurate adjustables. Here is a excerpt from a Mopar mag. It is referring to small block but the same holds true for bb engines.
Re: Valve train question [Re: bigcountry] #1385422
02/15/13 08:10 AM
02/15/13 08:10 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
How many miles do you have on this motor since this all happened?
It's kind of surprising you don't have a flat/ damaged cam lobe already from running those used lifters, and you'll be taking another chance when installing that new set.
A lot of people on this board aren't so lucky even with all new parts.
I hope this all works out for you and you've Dodged a bullet.
Re: Valve train question [Re: jbc426] #1385423
02/15/13 10:37 AM
02/15/13 10:37 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I would be asking why did it only happen on one? If all these assumptions were correct, you would have 16 pushrod problems, not one. IMO.
Re: Valve train question [Re: jbc426] #1385424
02/15/13 01:34 PM
02/15/13 01:34 PM
Upper Midwest
Upper Midwest
Over ther years Ihave seen people that put the lifters in a box and reused them when reassembling. Making sure that the lifters and cam are clean and well lubricated and they end result was no problem. Granted it isn't a good idea but if you have run it for even a relatively short time with no problem I would not worry about it and run it. Save your money for later up grades. The damage would have been virtually immediate.
Re: Valve train question [Re: Dodgeguy101] #1385425
02/16/13 12:53 AM
02/16/13 12:53 AM
Dallas, Texas
Dallas, Texas
That is why I asked this question. Most people say it just happens sometimes BUT I want to know the cause. These lifters have less than 15 miles on them plus 10-15 min idle time after installing them.
Re: Valve train question [Re: bigcountry] #1385426
02/16/13 01:10 AM
02/16/13 01:10 AM
I say V/P collision from valve float or something momentarily siezed from inadequate clearance. All pieces in related assy's are different (clearances/yield points etc) & will act different under fire. For a start I would check V/P clearance on ANY cyl. Something stacked em up solid (K.I.S.S. = vp collision)
Re: Valve train question [Re: RapidRobert] #1385427
02/16/13 11:26 AM
02/16/13 11:26 AM
maryland
74yellowduster Offline
maryland
yes this. and over 6000-6500 rpm or so (plus or minus) hydraulic lifters will pump up solid and cause problems. i dont think you were running over 6k, so it's more likely that your pushrods could be too long.
if you like running high rpms you should have solids (this requires adjustable rockers).
do you have a good local machine shop? you should go explain the issues they would probably show you how to measure things and get it right. you might need a cut-to-fit pushrod kit and the guys at the machine shop can help you get your baby right
my recommendation: get a solid cam / solid lifers / adjustable rockers / cut-to-fit pushrods / pushrod measuring tool / have a machine shop help or teach you all the details / know how to adjust them you will never have these problems again
Re: Valve train question [Re: Dodgeguy101] #1385428
02/17/13 12:36 AM
02/17/13 12:36 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
it can not be put more simply than that. lifters dont just get holes sometimes. post a photo of dammaged parts.......
Re: Valve train question [Re: ek3] #1385429
02/17/13 07:57 PM
02/17/13 07:57 PM
Dallas, Texas
Dallas, Texas
How do you post pictures here?
Re: Valve train question [Re: bigcountry] #1385430
02/17/13 08:13 PM
02/17/13 08:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
one way is to leave I want to preview my post and/or attach a file
checked then it will have a place to choose file to attach file must be resized small enough to be allowed.
Other is to go to Photobucket.com join upload your photo there click the photo and there will be a links box to the right click the IMG line (second from bottom) the come hear and paste in your post Ctrl V or use paste in browser and line shows up and will show as a picture after you post
Re: Valve train question [Re: Dodgem] #1385431
02/19/13 01:55 AM
02/19/13 01:55 AM
Dallas, Texas
Dallas, Texas
Thanks Dodgem, I will try that soon.
