Valve train question #1385400
02/11/13 01:35 AM
02/11/13 01:35 AM
Dallas, Texas
bigcountry Offline OP
Dallas, Texas
Hello all, had my 69 A12 Superbee out a few weeks ago cruising the streets when I heard a poping noise coming from the carb. Limbed about five miles home doing under 20 mph..Took valve covers off and noticed pushrod had punched a hole thru rocker arm on number 5 cylinder exhaust valve. Took rocker arm shaft off and fished out the lifter and noticed that it too had a hole punched in it. Have never heard of a push rod going thru both lifter and rocker arm before and can't figure out how it could be possible. The valve is not stuck. Put lifters, rockers and rocker arm shafts from another 440 in and it seems to run fine. Any ideas on what the cause of this is? Most people don't seem too concerned, but I would like to know what caused this. Thanks and take carer, B.C..
Re: Valve train question [Re: bigcountry] #1385401
02/11/13 12:50 PM
02/11/13 12:50 PM
Hyd lifter I'm assuming. Piston to valve collision? How much preload do you have? More details on what was punched thru on the lifter.
Re: Valve train question [Re: RapidRobert] #1385402
02/11/13 01:07 PM
02/11/13 01:07 PM
SE PA
Yellow Fever Offline
SE PA
You took used lifters from another motor and put them in? I doubt it will last very long, should have just put one new lifter in or all new lifters.
Re: Valve train question [Re: Yellow Fever] #1385403
02/11/13 01:22 PM
02/11/13 01:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I was thinking the same thing , good luck ...
Re: Valve train question [Re: JohnRR] #1385404
02/11/13 11:28 PM
02/11/13 11:28 PM
Dallas, Texas
Dallas, Texas
Yes hyd. lifters..don't know what the preload was, it had shims on the shafts along with lifters that were a little longer. Guessing shims were used for preload and to offset longer lifters to allow for clearance. Lifters were only put in to make sure engine was not further damaged. New lifters will be installed this weekend. The push rod went thru rocker arm and was wedged about 1.5-2 inches thru rocker arm.
Re: Valve train question [Re: bigcountry] #1385405
02/12/13 12:54 AM
02/12/13 12:54 AM
I'd pull the valve springs off of the offending cyl with an on eng valve spring compressor & check piston to valve clearance with a pair of light checking springs. The rocker arm could have failed from high spring pressure but you said the lifter was punched thru also. I would suggest some more checking unless you're sure V/P clearance is adequate
Re: Valve train question [Re: RapidRobert] #1385406
02/12/13 01:21 AM
02/12/13 01:21 AM
Dallas, Texas
Dallas, Texas
Yes both lifter and rocker were punched thru. Can't figure out why piston to valve clearance or spring tension would become an issue at this point?? Motor probably had 3000 miles on it with this setup. Any ideas? By the way thanks for all the input and help.
Re: Valve train question [Re: bigcountry] #1385407
02/12/13 01:33 AM
02/12/13 01:33 AM
Kirkland, Washington
Pacnorthcuda Offline
Push rods wearing through the stamped steel stocker rockers is not unheard of at all. A pushrod punching a hole Ina lifter ??? Would lie to see a pick of that! Can't see both happening either.
Weird.
Re: Valve train question [Re: Pacnorthcuda] #1385408
02/12/13 01:50 AM
02/12/13 01:50 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would check to make sure oil is getting to the rocker arms, were any restricters put in the block? Unless a big cam they should last many many miles.
Re: Valve train question [Re: cudaman1969] #1385409
02/13/13 01:16 AM
02/13/13 01:16 AM
Dallas, Texas
Dallas, Texas
Plenty of oil on rocker arms, shafts and lifters.Seems to me pushrod would have to punch hole in lifter first, since it was wedged 1.5 inches approx. thru rocker.
Re: Valve train question [Re: bigcountry] #1385410
02/13/13 10:25 AM
02/13/13 10:25 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
When you're saying the pushrod punched a hole through the lifter, can you describe what that looks like or post a picture?
Did the lifter have a hole through the bottom of it and look a bit concave where it meets the cam?
Re: Valve train question [Re: bigcountry] #1385411
02/13/13 11:40 AM
02/13/13 11:40 AM
JohnRR Offline
JohnRR  Offline
Was the block decked and the heads surfaced also ? Adding shims under the rocker shafts is the WRONG way to fix what is one of your real issues ... pushrods that are TOO LONG.
Re: Valve train question [Re: JohnRR] #1385412
02/13/13 12:12 PM
02/13/13 12:12 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
It seems to me the pushrod would bend before punching a hole through the lifter. There's a lot of metal to go through on a lifter...and if it went through the lifter first, the pushrod probably couldn't even reach the rocker arm and vice versa.
Re: Valve train question [Re: bobs66440] #1385413
02/13/13 11:05 PM
02/13/13 11:05 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
If the lifter face had a hole in it (worn) you can stop doing anything and closely inspect the camshaft without the intake in place. You have engine damage and the more you swap in used parts and run it the more damage is done. If the cam lobe that killed that lifter is also damaged (and no, it running with another used lifter for ANY time is not helping) then you have serious repairs. Inspect it. Closely. Immediately.
Re: Valve train question [Re: bobs66440] #1385414
02/14/13 01:30 AM
02/14/13 01:30 AM
Dallas, Texas
Dallas, Texas
Well the pushrods from both 440's are the same length. Have the heads been surfaced/block decked...will have to check, I dont know. The lifter face is not where the hole was punched, it is on other end where pushrod meets. The lifters I pulled from Superbee are a little longer than the ones that I pulled from, another 440. Put the two different lifters side by side WITH the shim on top of shorter lifter and they are the exact same length. I figured the shims, which are NOT homemade, were added under the rockerarm shafts for clearance??I was told shims were used before ajustable rocker arms were around?
Re: Valve train question [Re: bigcountry] #1385415
02/14/13 07:45 AM
02/14/13 07:45 AM
bobs66440 Offline
bobs66440  Offline
Yes, the shims are used to adjust lifter preload. Some say they really aren't a good idea because they effectively increase the diameter of the rocker shaft, which makes them too snug for the pedestals in the head and causes them to crack. I've never actually seen one crack, so I'm not sure if it's true, but it sounds logical. Adjustable rockers are better, but expensive. If you want to use the stock rockers, the correct way to adjust preload is to get a custom set of pushrods made. That's what I did with mine.
Re: Valve train question [Re: bobs66440] #1385416
02/14/13 02:07 PM
02/14/13 02:07 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Shims are "bad" because they move the centerline of the rocker shaft. That in turn can negatively affects the path the rocker follows - they affect the geometry of the rocker. So you add shim to adjust for the wrong pushrod, and the rocker tip ends up riding slightly off in terms of it's path accross the top of the valve. So for the cost of pushrods you run the risk of wearing the guides faster, valvetrain instability, wearing the rockers faster, and wearing the valve stem tips faster.
Re: Valve train question [Re: bigcountry] #1385417
02/14/13 02:23 PM
02/14/13 02:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Case height of the lifters don't mean didily. The preload is determined by the depth of the plunger after the rocker shaft is tightened down with the lifter on the base circle of the cam with the lifter, push rod, and rocker all in place.
Re: Valve train question [Re: moper] #1385418
02/14/13 02:34 PM
02/14/13 02:34 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Normally shims are used when the heads have been milled. When nonadjustable rockers are used if the heads are milled the push rods will hold the valves open. If both the rocker and lifter were damaged I would look closely at the rocker shaft for galling and the valve sticking. Your problems just are not normal.
Re: Valve train question [Re: MoparforLife] #1385419
02/14/13 02:38 PM
02/14/13 02:38 PM
bobs66440 Offline
bobs66440  Offline
Exactly right. When I was building mine, I had two different brand lifters side by side. They had different overall heights but the distance from the plunger and the face where the lifter meets the cam was the same. That's the dimension that matters.
