Re: Reproduction 68 -70 B-body , bendix boosters !!!!
[Re: 469runner]
#1384695
02/11/13 12:31 AM
02/11/13 12:31 AM
Posts: 4,799 ILL
MLR426
ILL
Glad to see them available. Though, the rear half shouldn't have ribs around the perimeter.
It doesn't have ribs around the perimeter. Look again. looks pretty correct to me with a pic. There goes my originals.
MLR426
[Re: 469runner]
#1384696
02/11/13 12:32 AM
02/11/13 12:32 AM
Figures, the spare that I have been holding onto and paid top dollar for probably just dropped in value by half of what I paid!
[Re: DoctorDiff]
#1384699
02/11/13 01:52 AM
02/11/13 01:52 AM
Ok, good. Didn't have mine available right now to look at. Thanks for the info!
[Re: DoctorDiff]
#1384700
02/11/13 02:29 AM
02/11/13 02:29 AM
Posts: 18,157 Mass
DAYCLONA
Mass
OEM Bendix boosters were smooth around the base, not stepped like the repro units.
Agreed,...but not a bad looking repro though, time will tell how the fit/function is amongst buyers,...Wayne (RAMMAN) from Fort Wayne Texas has also introduced a line of Bendix boosters if anybody is looking?
Here's the HEMI and the B body Bendix for comparison to the above post
Mike
[Re: DoctorDiff]
#1384703
02/11/13 04:21 AM
02/11/13 04:21 AM
Wait, so Wayne (Ramman) is selling / making the ones that he makes with the step on the back part? I thought he was only rebuilding them and making specific parts, not the whole thing?
[Re: DoctorDiff]
#1384706
02/11/13 02:25 PM
02/11/13 02:25 PM
Posts: 384 under the hood
A47
under the hood
thanks guys , for all the replies & info , no idea where they madethen ?? also , wonder why 68 /69 hemi B- Body cars came with a Bendix booster even when it was drums all round , well the ones i've seen have been bendix , yet the midland & ross on all other engine combinations
[Re: A47]
#1384707
02/11/13 05:10 PM
02/11/13 05:10 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
The Bendix is what will clear the valve covers/hood up on the bracket, Midland/Ross has a bigger diameter .
[Re: JohnRR]
#1384710
02/12/13 09:13 AM
02/12/13 09:13 AM
A47
under the hood
thanks guys for all the feed back & infomation !! its been appreciated nother question i'm been thinking about , is there any performance differece on the bendix and midland & ross , ?? of just a fixe / fitment thing !! ????
[Re: A47]
#1384711
02/12/13 09:41 AM
02/12/13 09:41 AM
The Midland-Ross booster is a single diaphragm booster meant for drum brakes. The Bendix booster is a dual diaphragm booster meant for the disc brake master cyl. Granted, the Bendix is a smaller diameter than the Midland-Ross so that could be why it has to have a dual diaphragm.
[Re: ]
#1384712
02/12/13 11:56 AM
02/12/13 11:56 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I recently parted a nice clean all original 1969 Sat wagon that had 4 wheel drum brakes, and a dual diaphram Bendix booster....
[Re: DAYCLONA]
#1384713
02/12/13 03:45 PM
02/12/13 03:45 PM
Dayclona is right. I forgot about the wagon drum brake application. I wonder if it gives more stopping force or less pedal effort for stopping force due to the dual diaphragms?
[Re: A47]
#1384715
02/12/13 05:04 PM
02/12/13 05:04 PM
Granted, I havent driven a car like mine with the midland ross booster, but my 69 charger that has the bendix disc brakes if you hit the pedal too hard, you'll end up going through the windshield! LOVE, LOVE, LOVE my brakes! Wish the ones in my 07 F150 were this good!
[Re: ]
#1384716
02/15/13 11:59 AM
02/15/13 11:59 AM
A47
under the hood
wonder if the midland & ross requires more vacuum to opperate as opposed to the bendix ? just throwing a few ideas out there !! like i mentioned bendix on hemi but wedge motored 68 -70 b bodies midland & ross !! & bendix on a hemi car , thinking giving better stopping power with less vacuum being generated with a hemi motor due to cam , maybe never seen a roadrunner or charger with a wedge & powr drums with a bendix booster !! wonder why just some thoughts guys , thanks again for all your imput & feed back
[Re: A47]
#1384717
02/15/13 12:11 PM
02/15/13 12:11 PM
JohnRR
U.S.S.A.
HUH ????
[Re: A47]
#1384718
02/15/13 02:12 PM
02/15/13 02:12 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've run the Midlands and Bendix boosters on wedge and HEMI cars with "big" (large dur.) cams, really doesn't matter as to the booster used, ...vacumm supply is key, generally 10" of vac minimum is fine for a manual car, as the engine recovers vacumm for the booster when you clutch to engage the brakes at low speed operation, the same engine set up with an automatic generally cannot substain repeated braking at low speed operation, which usually requires the need for a reserve canister in the system, or in worst cases, a vacumm pump
Mike
[Re: DAYCLONA]
#1384719
02/17/13 12:53 PM
02/17/13 12:53 PM
A47
under the hood
more good infomation !! the 440 in my satalitte with current cam idles in gear with foot on brake at 10hgs of vacume thinking of buying this booster to fit with none power drums seems a better deal sourcing the midland & ross booster , master cyliner / fire wall plate & pedel bell crank linkage !! thanks again !! for all the feed back !! given me some things to think about
