Re: Will I need to change My rear end?? [Re: JohnRR] #1384662
02/11/13 01:52 PM
02/11/13 01:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
why not back brace it? That should help. 3100lbs is light enough.
Because in the end the weak link is still the GEARS , see the picture above .
I definately say a prayer and cross my fingers every time I leave the burnout box and stage.............8 3/4, stock caps, backbrace and 30 spline axles and at 3200 lbs to boot however, no dana under my car and I should be at or around 3000 lbs. soon........
Re: Will I need to change My rear end?? [Re: JohnRR] #1384663
02/11/13 02:07 PM
02/11/13 02:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yup I did the same to a 30+ year old set of 3.91 when 6 psi of boost was added to the mix. replace w/ a nodular from randy's and fresh set of Yukons and zero isses. 3850lb 12.0 car.
Re: Will I need to change My rear end?? [Re: Mr.Yuck] #1384664
02/14/13 01:54 AM
02/14/13 01:54 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Mark, where are you located? If anywhere near central ohio, I can help with fab work narrowing a truck housing. I have a narrowing jig to do just about any of the common axle/end combinations. I too used a dana from a truck and other than the tubes being thicker they are great. If it is leafsprung you may need 3 1/8" u-bolts and modify your lower shock mount/sping plate holes and new perches. hope this helps. Beep
Re: Will I need to change My rear end?? [Re: 70Dart499] #1384665
02/14/13 03:14 AM
02/14/13 03:14 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I have to agree that you will not last long with the 8 3/4 , I had one that was back braced with spool & great gears in my 3450 lbs 63 , it did not last 8 races , went with the Dana 60 . My focus is not in the rear end now , just my 02 . Gary
