cam help ID #1384284
02/09/13 10:39 PM
02/09/13 10:39 PM
VA.
mosweethemi Offline OP
VA.
HEY I GOT A NEW ROLLER CAM WITH SOME OTHER ENGINE PARTS, THEY WERE ALL BIG BLOCK MOPAR. I WAS TOLDED THAT THE CAM WAS A CRANE 625. THE NUMBERS ON THE BACK ARE 689356 TOP O1D2R BOTTOM CAN ANY ONE HELP ME PLEASE ? I COULD NOT FIND THE CAM IN CRANE CAMS, OR COMP CAMS.THERE IS LIKE A GOLD PAINT BETWEEN THE LOBE (ITS A THREE BOLT)
Re: cam help ID [Re: mosweethemi] #1384285
02/10/13 12:15 AM
02/10/13 12:15 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
#1 call Crane or Comp and check with them.
#2 have it checked by a cam Doctor program as The cam # is not always the exact same grind and could have custom changes or be reground
that's the way I would go
home of the
Sox and Martin Hemi Duster
Re: cam help ID [Re: HEMIFRED] #1384286
02/10/13 04:02 PM
02/10/13 04:02 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The numbers you've supplied are the semi-finished Crane Cams core number and the heat treat batch code. Are there any numbers on the front of the cam? Regards, Chase
