Re: speedo head swap?
[Re: 340SHORTY]
#1384089
02/10/13 02:46 PM
02/10/13 02:46 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The things a guy will do for his buddiesa on Sunday. . Ok, the speedo head on the 80s trucks attach from the face. The 70s trucks and B body speedo heads attach with 2 screws into the back of the head but use the same cable hookup. . I had to remove the part of the circit board and housing to clear the odometer spool. I soldered the jumper wires in place. I need to find something to seal the opening I made. You can also see the little LED lights I installed for better illumination.
I am truckless..
