Re: Alternator: how would you repair this?
[Re: 70runner]
#1382750
02/07/13 01:31 AM
02/07/13 01:31 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Take it to an overhaul shop and tell them you need it repaired and the necessity to keep it original. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 70runner]
#1382751
02/07/13 01:38 AM
02/07/13 01:38 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know of a way to make that dissapear but you could epoxy it with something like J.B. Weld. I'd mold a blob around it filling the threaded hole and all, then when cured shape it by filing and sanding to correct shape then re-drill and tap the hole. You could also try a product called "Muggy Weld" which is a soldering rod used to repair pot metal which has a low melt temp and try the same method as above. I'd first practice either method on a spare junk core before trying it on your original.
[Re: BDW]
#1382754
02/07/13 11:03 AM
02/07/13 11:03 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Can the tab be replaced if you take it apart? How is it attached to the case internally?
It's not attached,it's part of the case.
[Re: A12]
#1382757
02/07/13 11:59 AM
02/07/13 11:59 AM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Silver Solder with a small metal shield under it, fill it and drill it.
There's some really good silver solder out there you just have to find it.
I'd go this route , Tig is going to melt that hole thing off .
[Re: JohnRR]
#1382758
02/07/13 12:06 PM
02/07/13 12:06 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
is the date code on back housing ? I can't recall if not, get a new housing, but I think date is on front housing... not ?
[Re: JohnRR]
#1382760
02/07/13 12:33 PM
02/07/13 12:33 PM
62maxwgn
Blair County,PA
And you need silver solder that has the same or close to the same melting point as aluminum and the zinc content also matters.
[Re: 62maxwgn]
#1382761
02/07/13 12:59 PM
02/07/13 12:59 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
You could make an open ended tray or mold to hold the broken piece in place and then slightly warm up the two parts. Melt the silver solder in a small cup and then pour it into the threaded hole, kind of like recasting the part.
[Re: 70runner]
#1382762
02/07/13 01:21 PM
02/07/13 01:21 PM
RapidRobert
silver solder it as said & if that didn't work or hold up then drill/tap a new mounting hole to the right of the original broken one (closer to the base) & fab up a new brush holder/bracket that will locate the brush back in the correct original position
[Re: ScottSmith_Harms]
#1382763
02/07/13 01:43 PM
02/07/13 01:43 PM
Posts: 180 3rd rock
kloyiod
3rd rock
Since when did J.B. Weld allow electricity to flow through it??? That's a new one on me!
[Re: 70runner]
#1382771
02/08/13 11:05 PM
02/08/13 11:05 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
Can someone recommend a specific brand of silver solder that would work?
The rear case (with the tab) has the date code and other OE markings that I want to preserve.
Correct and theremust be hundreds still kicking around . I may have one myself for a runner vert that I parted out . if you need it and i can find it and you want to pay shipping , its yours .
[Re: astjp2]
#1382773
02/09/13 02:36 AM
02/09/13 02:36 AM
Posts: 998 Sturgis S.D.
tripleblackcuda
Sturgis S.D.
