72-92 D-100: VAN control arms for lowering? #1382298
02/06/13 02:56 AM
02/06/13 02:56 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
A buddy asked me about the trick to get a cheap 2" lowering using stock parts. I seem to remember something I read here about using lower control arms from certain year vans...something about them having deeper coil spring pockets? Can anyone help elaborate a bit?
Thanks, Greg
Re: 72-92 D-100: VAN control arms for lowering? [Re: Kern Dog] #1382299
02/06/13 03:51 AM
02/06/13 03:51 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
As far as I know 78-98 at least
I've used them from an 80 to a 96 I know.
According to the online catalogs 78-98 are interchangeable
Height depends on how weak his springs are.
This is how high my RC sits in the front with just van LCA's & 225/60/15
Re: 72-92 D-100: VAN control arms for lowering? [Re: BulletBob] #1382300
02/06/13 03:56 AM
02/06/13 03:56 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Re: 72-92 D-100: VAN control arms for lowering? [Re: BulletBob] #1382301
02/06/13 03:59 AM
02/06/13 03:59 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I build a adjustable travel limiter to hold the springs in place & keeps the shocks from being the stop.
It goes where the rubber bumper goes
The shock mount gets lower too & if you use a shock for a 4000# front end you will only need the stop to keep the spring in place
Re: 72-92 D-100: VAN control arms for lowering? [Re: Kern Dog] #1382302
02/06/13 04:06 AM
02/06/13 04:06 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I chained mine when I cut the coil.
Pic of truck control arm. Coils sits on top
Re: 72-92 D-100: VAN control arms for lowering? [Re: 76dodgeboy] #1382303
02/06/13 04:10 AM
02/06/13 04:10 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just got this pic from the net. Van cotrol arm. As you can see spring sits down in a pocket.
Re: 72-92 D-100: VAN control arms for lowering? [Re: 76dodgeboy] #1382304
02/06/13 04:54 AM
02/06/13 04:54 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
This is it with the van steering stop removed & before my sawzall got a hold of the bump stop bracket
Re: 72-92 D-100: VAN control arms for lowering? [Re: BulletBob] #1382305
02/06/13 07:51 AM
02/06/13 07:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You do need to drill new strut rod holes in the van LCAs because they mount in a different place. Somebody needs to make a template for redrilling the holes.. I have a real nice pair Im not going to use if interested..
I am truckless..
Re: 72-92 D-100: VAN control arms for lowering? [Re: 340SHORTY] #1382306
02/07/13 02:26 AM
02/07/13 02:26 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have a template that I made a few years back Hidden in a tote in my basement somewhere.
I had too much help packing my shop stuff when we moved
I have a template made for flipping the front hanger or simply moving it up in 1" increments too
When I find it I'll make some for those who want one.
Re: 72-92 D-100: VAN control arms for lowering? [Re: BulletBob] #1382307
02/07/13 10:57 AM
02/07/13 10:57 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Greg, just park in a pot hole! Ok, I've helped enough.......
NO, no need to thank me. My work is done here.
Re: 72-92 D-100: VAN control arms for lowering? [Re: bigblock340power] #1382308
02/07/13 08:57 PM
02/07/13 08:57 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
This question was for Randy from the CCM club, Mike.
Your humor is appreciated though!
Re: 72-92 D-100: VAN control arms for lowering? [Re: BulletBob] #1382309
02/07/13 09:15 PM
02/07/13 09:15 PM
Lehigh Acres, Florida
rickstershemi Offline
I just made a template from the stock LCA using the ball joint as a location point and then transferred it to the Van LCA....worked like a charm
Picture of the Van LCA with located holes
Hope this helps
Also....we never had to limit the suspension travel....even with the stock /6 coils....but I did trim the bump stops down quite a bit....has never bottomed out
Rickster
Re: 72-92 D-100: VAN control arms for lowering? [Re: rickstershemi] #1382310
02/08/13 01:59 AM
02/08/13 01:59 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks everyone! I'll pass the words along.
Re: 72-92 D-100: VAN control arms for lowering? [Re: rickstershemi] #1382311
02/08/13 03:01 AM
02/08/13 03:01 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Hope this helps
Rickster
Where do I send my stamped, self addressed envelope to get a copy ??
I am truckless..
Re: 72-92 D-100: VAN control arms for lowering? [Re: Kern Dog] #1382312
02/08/13 03:20 AM
02/08/13 03:20 AM
Ca
76440 Offline
76440  Offline
Ca
Camper 9000 trucks also ran a pocketed lower control arm with bigger ball joint.
Re: 72-92 D-100: VAN control arms for lowering? [Re: Kern Dog] #1382313
02/08/13 06:11 AM
02/08/13 06:11 AM
Elk Grove, Calif.
Elk Grove, Calif.
And why would I be holdig back taking pot shots at him too? We're all fair game here!
Re: 72-92 D-100: VAN control arms for lowering? [Re: 76440] #1382314
02/08/13 12:39 PM
02/08/13 12:39 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
So did all True 1ton trucks with the 4400lb front axles. I say True 1ton because when a D350 has a 3300lb front axle rating its a halfton pretending to be a big boy
Re: 72-92 D-100: VAN control arms for lowering? [Re: 76440] #1382315
02/08/13 09:08 PM
02/08/13 09:08 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I actually have a Camper 9000 that I'll be turning into a trailer. It is a 2 wd, but I'm curious...The big ball joint...Does it require swapping more stuff in to work?
Re: 72-92 D-100: VAN control arms for lowering? [Re: Kern Dog] #1382316
02/08/13 09:21 PM
02/08/13 09:21 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
You have to use the 1 ton steering arm & drill the holes in the spindle from 5/8" to 3/4"
Re: 72-92 D-100: VAN control arms for lowering? [Re: 340SHORTY] #1382317
02/08/13 10:08 PM
02/08/13 10:08 PM
long gone....very easy to duplicate
Rickster
