Hot idle compensator - AFB Carb #1381917
02/05/13 02:18 PM
02/05/13 02:18 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
I'm in the middle of rebuilding my AFB's off a 1970 Hemi and noticed that the Hot Idle compensator is not working. Does anyone know if anyone sells these or if I really need to replace it. I know the functionally of the part just not sure if it really makes a huge difference in drivability?
thanks
Paul
Re: Hot idle compensator - AFB Carb [Re: Paul G] #1381918
02/06/13 09:45 AM
02/06/13 09:45 AM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
No comments?????
Re: Hot idle compensator - AFB Carb [Re: Paul G] #1381919
02/06/13 10:08 AM
02/06/13 10:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
How did you determine it was not working?
Re: Hot idle compensator - AFB Carb [Re: Challenger 1] #1381920
02/06/13 08:03 PM
02/06/13 08:03 PM
SE PA
Paul G Offline OP
Paul G  Offline OP
SE PA
I'm thinking if it is cold it should be closed/sealed? When I heat it up I do not see any movement in the metal parts?
Re: Hot idle compensator - AFB Carb [Re: Paul G] #1381921
02/06/13 10:43 PM
02/06/13 10:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They are not available that I am aware and most originals have been ruined by either time/age or repeated media blasting during rebuilds. They are just a controlled vacuum leak and there is an easy fix, simply plug the hole underneath with a lead plug and leave the old one in place for decoration (visiual accuracey). A bad one is often the cause of an erratic idle, a plugged one will be fine, you won't even miss it.
