whats a good year for a 5.9 (non LA block) #1381808
02/05/13 12:20 AM
02/05/13 12:20 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
going to be looking here in a few months whats a good year 1995-2000?
Re: whats a good year for a 5.9 (non LA block) [Re: theraif] #1381809
02/05/13 12:40 AM
02/05/13 12:40 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Good for what? A block is a block, especially once you get into the Magnum stuff like what youre talking about
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: whats a good year for a 5.9 (non LA block) [Re: 69L78Nova] #1381810
02/05/13 12:52 AM
02/05/13 12:52 AM
my own world
theraif Offline OP
theraif  Offline OP
my own world
the only thing i know about Magnum stuff the heads are different from a LA, so you are saying that all the years have the same compression ratio and ones from lets say a 3500 truck is the same as a durango. what i am looking to do is pull the heads do a little work a bigger cam a m1 intake
Re: whats a good year for a 5.9 (non LA block) [Re: theraif] #1381811
02/05/13 01:22 AM
02/05/13 01:22 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
there may have been some minor changes from the OBD-I to the OBD-II model years, but yes, in the same year, a 5.9 out of a Dakota R/T is the same exact motor as a 4x4 Jeep as a 3500 Ram pick-up.
same block, crank, rods, pistons, cam, intake, heads, etc. you will see that some vehicles have higher Hp ratings, but that's because of muffler changes, such as on the Dakota R/T that was listed at 5 hp more than other equivilent vehicles.
the stock long block is good for about 400 crank hp with just a cam, intake, and exhaust change.
**Photobucket sucks**
Re: whats a good year for a 5.9 (non LA block) [Re: 70Cuda383] #1381812
02/05/13 03:16 AM
02/05/13 03:16 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A lot of confusion over the R/Ts... When the R/T came out it got a better cam, in 2000 all 5.9s got the same cam, I have measured a bunch of them and have found that 100% accurate so both the people who say the R/T got the same cam and people who say they got different cams are correct. 318 heads seem to hold up a lot better than 5.9 heads, could be better QC at the factory they were made in or it could be that the 5.9 got death flashes that allowed the burning exhaust to burn the seats and valves or the lower compression doing the same thing. 92 and 93 magnums had the best ex. manifolds. Somewhere in the early 2000s they all got a much better Y pipe.
Re: whats a good year for a 5.9 (non LA block) [Re: 70Cuda383] #1381813
02/19/13 08:56 AM
02/19/13 08:56 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Really...??? I know they're very underrated, but that much?
How much cam are we talking to make that? (I'm assuming an RPM intake/proper carb and full longtubes/GOOD exhaust).
I am THIS close to selling my big block parts for the Challenger and looking for a drop-in 318 or 360 Magnum.
Re: whats a good year for a 5.9 (non LA block) [Re: Pale_Roader] #1381814
02/19/13 10:45 AM
02/19/13 10:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
whatever the cam specs were in the 380hp crate motors... Mopar muscle put the 380 crate on the dyno and made like 408 crank hp. I'm thinking it was up around 230° @ .050, 110 LSA? maybe someone else can say exactly what the specs were on those crate motors. the heads as cast flow in the 200 CFM range, which is good for 400 hp if you get a cam that uses all that CFM. but, like I said, the stock intake isn't going to be making 400 hp, because it's all used up by 3800 rpm.
Re: whats a good year for a 5.9 (non LA block) [Re: 70Cuda383] #1381815
02/19/13 10:15 PM
02/19/13 10:15 PM
dogdays Offline
dogdays  Offline
I agree with the big guy. Heck, a 360 will do 400 hp with cam, intake and exhaust swap, and the 5.9 has much better combustion chambers and exhaust flow.
R.
Re: whats a good year for a 5.9 (non LA block) [Re: dogdays] #1381816
02/19/13 11:25 PM
02/19/13 11:25 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
R.
So you are saying that the low compression, 50,000 mile 1974 360 truck engine I have, could turn into a little beast with the right cam, the air gap eddy intake, and the cnc ported eddy heads (61 cc chambers, 292 cfm at .600 intake, 211.5 cfm exhaust), and good headers. I was considering the '70-71 highfow exhaust manifolds with electric cutouts. Or a small turbo for those times when you want just a little more.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: whats a good year for a 5.9 (non LA block) [Re: 70Cuda383] #1381817
02/20/13 12:20 AM
02/20/13 12:20 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I agree 100%.
A local guy bought a 380 crate engine for his Cuda and using the recommended parts, a 750 Holley and headers- the engine tipped the dyno at 417hp
Re: whats a good year for a 5.9 (non LA block) [Re: DusterKrazy] #1381818
02/20/13 04:07 AM
02/20/13 04:07 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
A stock one will make 300 easy with just a carb,intake & distributor
Re: whats a good year for a 5.9 (non LA block) [Re: BulletBob] #1381819
02/20/13 04:12 AM
02/20/13 04:12 AM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
Is there any way to remove a death flash, buddy has a truck with it. My 95 318 will smoke his 96 360.
Re: whats a good year for a 5.9 (non LA block) [Re: 70Cuda383] #1381820
02/20/13 09:24 AM
02/20/13 09:24 AM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
228/232 .501/.513 Don't remember LSA. I think this cam can support more HP than your typical stock magnum heads can flow so upgrading heads later would not necessarily mean upgrading the cam. I believe it was used on some of the higher HP bigger inch crate engines as well. I am happy with it in my junk!
Re: whats a good year for a 5.9 (non LA block) [Re: BigDawg72] #1381821
02/21/13 08:48 AM
02/21/13 08:48 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I see Hughes has a new Whiplash cam for the 360 Magnum. Duration is in the 220's i think, lift over .500". That should about qualify, yes? Spendy though... $400. Compared to their other Magnum sticks anyways.
360 Magnum, RPM Air-Gap, Holley DP, Whiplash cam, long tube headers, 2.5" mandrel exhaust, stick, 3100lb car... Hmmmmm... . . .
Re: whats a good year for a 5.9 (non LA block) [Re: 70Cuda383] #1381822
02/21/13 09:30 AM
02/21/13 09:30 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
One minor change i think was made in
1996 with the first year of OBD-11 was that the dish in the 5.9 piston crown was enlarged from about 11cc to about 14cc, and the piston to head clearance may have been increased a bit too, so the compression height or block deck height maching may have changed too.
The piston to block clearance of some of the 1994s seem to be in the range
0.50 to 0.59
while the after 1996 ones seem to be
0.70 to 0.80 inches
The 1995 Field Service Manual specification table
lists the static compression ratio for that year Magnum 5.9V8 as 9.1
In 1996 and beyond Chrysler advertised the Magnum 5.9 v8 as static compression ratio 8.9
OBD-1 had egr to help control NOx
Then this was dropped with OBD-11 in 1996
and it makes a little sense that they might have had to
drop compression a bit
with a changed cam and
a different catalytic converter as part of the emissions control.
Willem Weertman says in his book
"Chrysler Engines"
that the 1994-1995 iron block Truck V10
used the same eutectoid alloy cast aluminum pistons as the
1993-1995 Magnum V8 as a cost saving measure.
I have a set of 1994 pistons from a Magnum 5.9 that i measured
a compression height of 1.61 inches,
11 cc piston crown dish and
472 grams bare piston weight without rings or pin.
Re: whats a good year for a 5.9 (non LA block) [Re: theraif] #1381823
02/21/13 01:25 PM
02/21/13 01:25 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
The BEST 5.9 block for power is...
(Wait for it)
(Wait for it)
(Wait for it)
The BEST 5.9 BLOCK for power is A 5.9 CUMMINS.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: whats a good year for a 5.9 (non LA block) [Re: Evil Spirit] #1381824
02/21/13 05:21 PM
02/21/13 05:21 PM
USA
3
360view Offline
360view  Offline
3
USA
What,
no credit for the turbo
or intercooler?
Cummins made a propane normally aspirated B block engine for schoolbuses.
It had the block,
but the power,
not so much.
