Re: 8 3/4 bigbolt axle versus wheel adaptors
[Re: MoparTod]
#138135
10/18/08 07:56 PM
10/18/08 07:56 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Sounds like a lot of money in shipping just to get them redrilled. I thought I read somewhere there was not enough room in some of the small bolt axles to redrill a second set of holes. free bump
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#138136
10/20/08 08:30 AM
10/20/08 08:30 AM
Posts: 15,487 Florida
scratchnfotraction
moser has axles with the 4.5 wbp and the large brake offset and green bearings 299$ a pair you need the backing plate,brake hardware,and drums to go with the axles I used some from a 73 newport and got 11x2.5 brakes with there axles when I done my 68 Dart 8 3/4 rear it made the whole rear a 1/2" wider also back space on my wheels was 4 1/2" back space
