Re: 727 Trans Problems
[Re: Mike Swann]
#1379562
02/01/13 08:47 AM
02/01/13 08:47 AM
Posts: 106 NY VA USA
GTXbound
NY VA USA
I always did mine in 2nd and never had a problem.
hahaha What do you mean?
[Re: GTXbound]
#1379563
02/01/13 09:09 AM
02/01/13 09:09 AM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
With the Cheetah RMVB, the low/rev band is NOT applied in "1". Only elements applied are the forward clutch and the over-running clutch is holding in "1". If it is slipping in "1", I might suspect that the over-running clutch rollers/springs have started to "lay over". The forward clutches are applied in ALL forward gears, so if the clutches were slipping, it would in 2nd and 3rd. The over-running clutch free wheels in 2nd & 3rd, so you would not notice slipping in those gears. More analysis needed to pin point, may include dropping the trans. If the over-running clutch is starting to fail, you are inviting an explosion of the direct clutch drum. Easy place to start - drop the pan and look for metal shavings.
John
[Re: Mike Swann]
#1379565
02/01/13 12:47 PM
02/01/13 12:47 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
DusterW2 is correct. However what he calls the forward clutch is more commonly reffered to as the rear clutch because it's behind the front clutch in the assembly. It has nothing to do with reverse though as that is handled by the rear band and the front clutch. Confused yet?
[Re: Guitar Jones]
#1379566
02/03/13 12:09 PM
02/03/13 12:09 PM
GTXbound
NY VA USA
Hey Guys thanks for all the answers i told him what everyone said and he agreed to pull trans out and take it to trans shop to check it out. what billet drum do you guy use ? i know he dont have a big budget to spend right now but i think i can push him in to buying it based on safety.. thanks
[Re: Leigh]
#1379568
02/03/13 12:52 PM
02/03/13 12:52 PM
GTXbound
NY VA USA
Did he buy the valve body new? Has it ever worked? Did someone take it apart?
Yeah he did buy it new bout 10+yrs ago and the trans was built back then.
but he didn't start running the car till now.
He finally got everything together motor wise. It took him kinda a long time but thats life.
the car had about 1/4 inch of dust on it hahaha.
[Re: Leigh]
#1379570
02/03/13 06:11 PM
02/03/13 06:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Your buddy needs a sprag and while in there he should buy a new billet front drum. A&A and TCS both sell them.
[Re: GTXbound]
#1379572
02/03/13 07:40 PM
02/03/13 07:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If it sat 10 years the valves in the valve body COULD be all corroded and not working right(as well as the regulator)... just something to look at
