741 Posi Pin w Green Bearings? #1379354
01/31/13 11:56 AM
01/31/13 11:56 AM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
Remove it or keep it in????
Re: 741 Posi Pin w Green Bearings? [Re: 440PURSUIT] #1379355
01/31/13 12:18 PM
01/31/13 12:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Chirs I've always taken them out. Although I've been told it makes no difference. When can I come pick up my Cal-Tracs?
Coming soon!!!!
Re: 741 Posi Pin w Green Bearings? [Re: Mr.Yuck] #1379356
01/31/13 12:19 PM
01/31/13 12:19 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I left mine in..
I am truckless..
Re: 741 Posi Pin w Green Bearings? [Re: 340SHORTY] #1379357
01/31/13 03:44 PM
01/31/13 03:44 PM
scratchnfotraction Offline
make sure to use the M-400 bearing with snap ring like DrDiff sells.you can leave it in with the M-400 bearing.
remove it if you have the mopar bearings with crimped on retainer. those will pre-load the bearings = failure.
if it has buttons you can remove without a teardown, then I would remove them anyways.
