Real 904 power limits #1378487
01/30/13 10:42 AM
01/30/13 10:42 AM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
I would like to hear from those that have used 904's in some high hp applications. I also know it would be better to use a 727 so I don't need that info. Just wanting to know what it takes to make one live for a while. Will be behind 800hp small block, 3000lbs. Thanks in advance.
Re: Real 904 power limits [Re: w2dak394] #1378488
01/30/13 11:37 AM
01/30/13 11:37 AM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
ProTrans is 904 guts in a 727 case. True that the 904 parts are the best available, aluminum, billet, etc., but these trans hold up fine at 1000+ HP and 600+ Tq in 3200 to 3800 lb Super Stock cars, ET's in the low 8's to mid 9's. Good parts will live fine.
Be a Rebel- Break the Laws of Physics!
Re: Real 904 power limits [Re: mbogina] #1378489
01/30/13 12:33 PM
01/30/13 12:33 PM
dogdays Offline
dogdays  Offline
The question can be answered by another question,"How much money do you have?"
R.
Re: Real 904 power limits [Re: w2dak394] #1378490
01/30/13 12:36 PM
01/30/13 12:36 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I agree with "MBOGINA" call Dave at Protrans about your combo 661-940-7400.
"Just a Bracket car dressed up like a streetcar"
Re: Real 904 power limits [Re: mbogina] #1378491
01/30/13 12:43 PM
01/30/13 12:43 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
uNder these applications ... don't they have to be freshed-up every 20 or so passes?
Re: Real 904 power limits [Re: dogdays] #1378492
01/30/13 01:11 PM
01/30/13 01:11 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
R.
If he has enough money to build a 800hp SB then he better have enough to buy a good trans, ect ect ect
Protrans !!!!
Re: Real 904 power limits [Re: 10.90 Racer] #1378493
01/30/13 01:24 PM
01/30/13 01:24 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You can try Rick at A1 also. increased line pressure, and harden input and output shafts. That is the horsepower level I was breaking out put shafts but with at little more weight 3350lbs. It can be done but expect to have 3500-4500 in your trans. I switched to a 727.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Real 904 power limits [Re: w2dak394] #1378494
01/30/13 02:44 PM
01/30/13 02:44 PM
gregsdart Offline
gregsdart  Offline
A better question is how much torque will a 904 hold? Torque is what pushes parts to their limit, not hp. a 500 hp low rpm diesel would shredd a 904 in seconds. A 600 hp 340 cube small block in front of it, and it will live a very long life. A loose converter also helps, because the trans no longer gets hit with the harsh shifts of a stock converter that will bark the tires at 50 mph. My uneducated guess is about 500 ft lbs is a good range to stay at or below. Maybe one of the trans experts will chime in with some more input.
Re: Real 904 power limits [Re: dOc !] #1378495
01/30/13 03:46 PM
01/30/13 03:46 PM
detroit area
moderncylinder Offline
detroit area
no they dont,, a planetary could break after 100 or so runs though,, so its a good idea to look at it every so often
if you run low line pressure you could burn it up,, a hemi car has about 150-175lbs
Re: Real 904 power limits [Re: w2dak394] #1378496
01/30/13 04:01 PM
01/30/13 04:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call Dave at Pro Trans and buy his all new Proflyte, no more problems with using any stock parts
Re: Real 904 power limits [Re: Cab_Burge] #1378497
01/30/13 05:19 PM
01/30/13 05:19 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
we have found the reliabilty of the ProTrans to be excellent. We did break a gearset a few years back when we ran the Cuda at minimum 3810+ lbs and we were pushing 640+ TQ, and we killed the forward clutches in it late last year at the Heartland Park Topeka Division Race, but typically we will freshen it up every 100 runs or so and we have no problems. The Protrans 727 is a full 25 lbs lighter than a stock 727, and .25 quicker.
Re: Real 904 power limits [Re: mbogina] #1378498
01/30/13 11:35 PM
01/30/13 11:35 PM
ms
W
w2dak394 Offline OP
w2dak394  Offline OP
W
ms
So if I'm understanding right u can install aftermarket shafts and drum, and stll break planetary gears. Would these shafts be called 300m shafts. What about the stock case will it be okay? If someone has a 904 built at home that will handle this power I would love to Speek with u.
Re: Real 904 power limits [Re: w2dak394] #1378499
01/31/13 01:06 AM
01/31/13 01:06 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Can't remember what thread it is on here, but I was doing some searching on here awhile back when deciding if I was going to run a 904 or 727 behind my SB and I believe someone had said that the limit for the stock shafts on these transmissions was 650-700hp??? After that they need some stout billet pieces to hold the power
Re: Real 904 power limits [Re: mbogina] #1378500
01/31/13 01:10 AM
01/31/13 01:10 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Just curious ....what is the price of this setup ?
Re: Real 904 power limits [Re: w2dak394] #1378501
01/31/13 01:35 AM
01/31/13 01:35 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
A 904 in a lightish car of say 3000-3200lbs will handle 500ft/lbs with most of the standard hard parts.
904's don't have the friction cross section that a 727, Powerglide or TH400 has, so they don't have the torque handling capability.
A Proflite is a different trans to a 904. It's a 727 AMC case, with custom drums etc and uses a Powerglide converter.
There isn't an aftermarket case for the 904 or 727, so the standard case is what you're stuck with.
I maxed out 904 is going to set you back around $5k in parts and is going to require a lot of maintenance. Most guys that run them always have a spare.
Alan Jones
Re: Real 904 power limits [Re: dOc !] #1378502
01/31/13 01:36 AM
01/31/13 01:36 AM
LA360 Offline
LA360  Offline
A Proflite starts at around $6K
Alan Jones
Re: Real 904 power limits [Re: LA360] #1378503
01/31/13 12:28 PM
01/31/13 12:28 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
A ProTrans can utilize a 727 case or a 904 case, ours use a BB 727 case and 727 convertors. With all the bells and whistles, 727 case, Trans Brake, position 6 nuetral, choice of about 30 gearset combos, 300M main shaft, all billet drums w roller bearings, cast alum pan, etc, yes, you are looking at about 6k, maybe a bit more. I believe all the same stuff in a 904 case is somewhat cheaper without the custom shafts to convert 904 sizes to 727, and the added labor to convert a 727 case to accept 904 guts. My nomenclature may not be 100% correct, but i believe that the ProTrans is the 727 and 904 Mopar versions, and the ProFlite are the GM cases converted to accept the 904 guts w powerglide verts for use in Comp Elim
Re: Real 904 power limits [Re: mbogina] #1378504
01/31/13 09:07 PM
01/31/13 09:07 PM
LA360 Offline
LA360  Offline
The Proflite is an AMC 727 case with an adapter plate for the bellhousing that is about 3/4"-1" thick
Alan Jones
