cranking compression
#1377566
01/28/13 03:08 PM
01/28/13 03:08 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I've asked this question before on another forum, but never got an answer. I know that the dynamic compression ratio is what determines what grade fuel is necessary, but what should the DCR and cranking compression be for the different grades of today's gasoline (87, 89, 91 octane)?
This is the land of the free
because of the brave
Re: cranking compression
[Re: rbstroker]
#1377569
01/28/13 04:55 PM
01/28/13 04:55 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
the gear ratio,converter,weight of car,& the comp ratio also play a role in your question.
[Re: CSK]
#1377570
01/28/13 04:57 PM
01/28/13 04:57 PM
Posts: 3,916 usa
lewtot184
usa
[Re: lewtot184]
#1377571
01/28/13 09:28 PM
01/28/13 09:28 PM
RapidRobert
Is the long block together or are you still in the planning stages? If together what SCR did you measure?
[Re: rbstroker]
#1377574
01/29/13 11:58 AM
01/29/13 11:58 AM
RapidRobert
unfortunately I am not a cam guy so I dont have a specific recommendation but with 7.31 dynamic I sure think you could go milder for more bottom end. I'm not sure the 528 would be a good choice. What was the SCR? & what calculator did you use to get the DCR? You mentioned the .050 lift & reportedly the calculators such as the ones at Wallace racing use lift @ .005 which gives a more accurate DCR figure. Sorry no help but here's a BTT. EDIT just reread & saw the 3.23's & I'll emphatically say avoid the 528 (& I'm not a cam guy)
[Re: RapidRobert]
#1377575
01/29/13 02:08 PM
01/29/13 02:08 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Please be detailed and tell us what your engine is now. Piston choice? deck height? head gasket used? head type (p/n)?
[Re: rbstroker]
#1377576
01/29/13 03:22 PM
01/29/13 03:22 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
So your saying you have stock stroke 440 with 8.3 to 1 compression giving a dynamic of 7.3 to 1 and 140 cranking with aluminum heads?? I would like to see the total workup on the engine, heads, exhaust and torque converter? Can't see where a .528 would perform much different maybe a few more ponies but even less bottom end but mostly the same. If you want more bottom end assuming the racer brown cam is 108 LSA advance the install to 102
[Re: rbstroker]
#1377577
01/29/13 03:43 PM
01/29/13 03:43 PM
Posts: 3,054 USA
b54406barrel
USA
When gas got spendy in the 80's, I rebuilt my 440-6 engine to pretty much stock except with a set of low compression pistons. I measured it up & it was in the 8.5-6 range. I finally used a hughes cam with these specs, after running a tp-238 (230 @.050/480) for several years ;
Camshaft Technical Details Intake Valve Lift 1.5 .470" Exhaust Valve Lift 1.5 .506" Intake Duration at .050" 215° Exhaust Duration at .050" 223° Lobe Separation Angle 112º Intake Opening at .050" -1.5° BTC Exhaust Opening at .050" 46.5° BBC Intake Closing at .050" 36.5° ABC Exhaust Closing at .050" -3.5° ATC
Cranking compression was 150 or so, with the second cam. Runs just fine on 87, total mechanical advance of about 34-6%.
Whoops, I didn't mean spendy in the 80's, I meant crappy!
[Re: rbstroker]
#1377579
01/30/13 12:14 AM
01/30/13 12:14 AM
Dodgem
Ontario, Canada
well the .528 is 112 LSA and 241 @ .050
that racer brown with 238 duration should be fine but with that compression, 4 speed and gear and a 493 inch I would maybe advance it 102 but 105 should work real nice with 89 maybe even 87.
[Re: rbstroker]
#1377580
01/30/13 05:00 PM
01/30/13 05:00 PM
Dodgem
Ontario, Canada
On running numbers on My EA dyno I would leave the Racer brown installed where it is on a 383 or 440 maybe more advance but not on a 493. Should give you 450 foot lb @ 2500 and peak torque 540 @ 3500. Peak hp at 5000 so a 5500 all out shift point?? the solid .528 would give about 3 to 4 more hp and about the same more in torque not sure the switch to solid would be worth it??
