360 piston to head clearance
#1377102
01/27/13 02:47 PM
01/27/13 02:47 PM
Posts: 318 Fort Collins, Colorado
CoDart
I have a 360 magnum that I am putting thinner head gaskets on to raise compression. It has RHS indy heads and dished ICON forged pistons. The pistons are 0.005" below deck and the gaskets I was thinking about running are 0.025" thick. Here are the pistons Pistons What is the safe limit for piston to head clearance? Thanks
Re: 360 piston to head clearance
[Re: CoDart]
#1377103
01/27/13 03:01 PM
01/27/13 03:01 PM
RapidRobert
Hello Ori! .030 is pretty tight but could be done with tight piston/bore clearance (less piston rock) & carefull measureing & I'm assuming steel rods. Are these steel shim gaskets? Is the .025" thickness the listed or measured? It'd build up the height a bit & help sealing with some copper coat or aluminum spray paint. What's your SCR? Is the P/V clearance adequate?
