Wheel tubs? #1377069
01/27/13 12:46 PM
01/27/13 12:46 PM
London Ontario Canada Eh
Dono Offline OP
Dono  Offline OP
https://board.moparts.org/ubbthreads/show...vc=#Post7563223
Any tips on putting them together?
Cheers Don.
Re: Wheel tubs? [Re: Dono] #1377070
01/27/13 12:51 PM
01/27/13 12:51 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Should have come here first. Alot of guys just add to the stock ones. Do a search in the truck section.
Re: Wheel tubs? [Re: 76dodgeboy] #1377071
01/27/13 02:23 PM
01/27/13 02:23 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Insert tab A into slot B and use a hammer and dolly...
I am truckless..
Re: Wheel tubs? [Re: 340SHORTY] #1377072
01/27/13 03:08 PM
01/27/13 03:08 PM
Clinton Twp. Michigan
coronet1966d Offline
Thats how i did mine, either you can fabricate stuff like this or you cant. i had my cousin come over and do the welding and i used steel tubs from summit.
i actually saved my stock tubs if you wanted to just double up the stock tubs
Re: Wheel tubs? [Re: coronet1966d] #1377073
01/27/13 08:41 PM
01/27/13 08:41 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
With the stockers you are limited on how low you can go & how tall of tire you can use. The tubs like above look good & you can tailor the width & height to what you want without a seam in the middle to finish out.
Re: Wheel tubs? [Re: BulletBob] #1377074
01/27/13 09:59 PM
01/27/13 09:59 PM
scratchnfotraction Offline
I used a full set of stock tubs added to 1/2 of the tubs in the bed.
cut the floor right at the frame brace that sit on the frame.
Re: Wheel tubs? [Re: scratchnfotraction] #1377075
01/27/13 10:01 PM
01/27/13 10:01 PM
notice the frame brace and edge if tub.
Re: Wheel tubs? [Re: scratchnfotraction] #1377076
01/27/13 10:07 PM
01/27/13 10:07 PM
has a nice stock look,just fat.
Re: Wheel tubs? [Re: scratchnfotraction] #1377077
01/27/13 10:13 PM
01/27/13 10:13 PM
I should have used some of the rolled tubbes like John did on his with my stepside. the sidewall and tub has a nice round shape in a stepbed.
Re: Wheel tubs? [Re: scratchnfotraction] #1377078
01/27/13 10:15 PM
01/27/13 10:15 PM
Re: Wheel tubs? [Re: scratchnfotraction] #1377079
01/27/13 10:16 PM
01/27/13 10:16 PM
Re: Wheel tubs? [Re: scratchnfotraction] #1377080
01/28/13 10:49 AM
01/28/13 10:49 AM
orange,tx
O
onebadstepside Offline
O
orange,tx
heres mine
Small blocks rule!!!!!
