Need advice 340 vs 360 in A body #137673
10/16/08 05:21 PM
10/16/08 05:21 PM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
A friend wants to put a small block in a 68 Barracuda /6. We both have big block cars and don't know much about the small blocks. Which engine build would give him the best fit and performance for the money. He wants to run PS, PB and headders.
Re: Need advice 340 vs 360 in A body [Re: repad] #137674
10/16/08 05:32 PM
10/16/08 05:32 PM
IMHO.....
Both engines are of identical proportions. One fits as well as the other.
Unless you have a 340 already on hand, locating one to rebuild can be difficult at times.....and costly.
360's are everywhere.....both the LA and Magnum versions.
Personally I would build up a new Magnum 360 for it.
Sid
Re: Need advice 340 vs 360 in A body [Re: repad] #137675
10/16/08 05:34 PM
10/16/08 05:34 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
340 and 360's are identical in size as far as external dimensions. One isn't going to fit better than the other.
340's are usually harder to find and cost a lot more money than a 360. The price difference to rebuild either one is going to be pretty much the same. I have seen rebuildable 340 engines priced as high as $500.00. I bought my 360 core for $50.00.
If the car is going to have mild gears and an automatic I would use the 360 since they produce better torque all things being equal.
Re: Need advice 340 vs 360 in A body [Re: Neil] #137676
10/16/08 06:18 PM
10/16/08 06:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would say go with a 340 thats in good running condition as long as its an early high compression engine before 72. Youll pay more but you can go with more as far as cam goes and get more power in the end. To get the compression up on the 360 youll have to rebuild it if you really want high compression. Shaving the heads on the 340 can net you over 10:1 as was advertised from the factory if it doesnt have it that high already. Itd also start you with a 2.02 intake valve.
A 340 long block might run you 1500 bucks, but its cheaper than a 300 360 core and the price of a rebuild.
If hes going to rebuild go with the 360 so long as he doesnt need a forged crank to spin it to the moon, which it doesnt sound like hes trying to do.
By the way did the 340 have forged pistons? I dont know as im usually into the big blocks, I remember somone saying that they did come with them though some how. I doubt Im remembering correctly but if they did thats another plus right there.
Re: Need advice 340 vs 360 in A body [Re: GTX MATT] #137677
10/16/08 06:39 PM
10/16/08 06:39 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
No forged pistons in stock 340s.
In my opinion either motor is going to cost the same to rebuild.
The 340 has a higher initial by in. The 360 core is much cheaper and the longer stroke will give you a bit more low end grunt.
If you have a motor to start with build it, If not either one is capable of making a good street motor so buy which ever one you can get the better deal of. Most likely a 360.
Matt if I had the extra cash I would pick that motor up from you.
Re: Need advice 340 vs 360 in A body [Re: AdamR] #137678
10/16/08 06:59 PM
10/16/08 06:59 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Adam I sent you a PM
Re: Need advice 340 vs 360 in A body [Re: GTX MATT] #137679
10/16/08 07:16 PM
10/16/08 07:16 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Back at you.
Re: Need advice 340 vs 360 in A body [Re: AdamR] #137680
10/16/08 08:46 PM
10/16/08 08:46 PM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
He doesn't have an engine yet, so it looks like he'll be building a 360 since they are easier to find. An earlier poster mentioned using a Magnum over an LA, how can we tell the difference? Is there a good book on building smallblack mopars?
Re: Need advice 340 vs 360 in A body [Re: repad] #137681
10/16/08 08:52 PM
10/16/08 08:52 PM
NY usa
540challenger Offline
NY usa
The easiest way to tell a magnum from a LA engine is the valve covers.
LA has 5 bolts per cover
MAg. has 10 bolts per covers.
There are a ton of small block moapr books out there know.
Re: Need advice 340 vs 360 in A body [Re: 540challenger] #137682
10/16/08 09:00 PM
10/16/08 09:00 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Magnums have there pros and cons.
Hyd roller cam, Better heads but you will need a center sump oil pan, a LA timing cover and water pump, The cam isnt set up for mechanical fuel pumps but that cant be fixed with an aftermarket cam or bolt on snout. You also have to check the heads for cracks between the valves.
Re: Need advice 340 vs 360 in A body [Re: AdamR] #137683
10/16/08 09:25 PM
10/16/08 09:25 PM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
I can understand the need for a center sump pan but why an LA timing cover and water pump?
Re: Need advice 340 vs 360 in A body [Re: repad] #137684
10/16/08 10:40 PM
10/16/08 10:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
To make room for the extended snout on the camshaft. when Chrysler did away with mechanical fuel pumps they also shortened the cam and on the Magnums they shortened the timing chain cover. The pump was redesigned for th enew Magnum cover and won;t work properly on an LA cover.
Don;t forget accesories. You are not likely to want to run the Magnum accesories, especially if you run the LA cover. You may have alignement issues running LA accesories on a Magnum block, just check them when you build the engine.
As for 340 vs 360, assuming both need rebuilt, r both don't, my recommendation is this. Street - 360, strip - 340.
360 has a longer stroke, builds more torque, all else the same. Torque is better for a street car.
340 has a shorter stroke, will rev up quicker and be happier higher up making more HP, all else equal. HP is the ticket for the strip.
Be an interesting dyno test if you took a 340 and a 360, built them the same (compression, heads, cam, etc) and see what they did.
Don't be the exception.
Re: Need advice 340 vs 360 in A body [Re: Supercuda] #137685
10/16/08 11:36 PM
10/16/08 11:36 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
awwhhh...the old 340 is going to rev faster theory again...ever weight a stock 340 piston and pin....together they weigh over 800 grams...
Tony
70 AARCuda Vitamin C
Re: Need advice 340 vs 360 in A body [Re: 70AARcuda] #137686
10/16/08 11:41 PM
10/16/08 11:41 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
360 everytime!!!
Re: Need advice 340 vs 360 in A body [Re: goldmember] #137687
10/17/08 12:04 AM
10/17/08 12:04 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
360 everytime!!!
If the 360 would have been built instead of the 340 with the same specs as the early 340 no one would even bring the 340 up.
Re: Need advice 340 vs 360 in A body [Re: MoparforLife] #137688
10/17/08 12:08 AM
10/17/08 12:08 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Correct.
Re: Need advice 340 vs 360 in A body [Re: repad] #137689
10/17/08 07:26 AM
10/17/08 07:26 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Magnums also dont have the mechanical fuel pump boss and the water pump is reverse rotation I believe.
Re: Need advice 340 vs 360 in A body [Re: AdamR] #137690
10/17/08 07:41 AM
10/17/08 07:41 AM
ky.
K
kenworth_goose Offline
K
ky.
Go 360!! It will make far more power and torque with the same parts and compression as a 340. Yeah I said it. It will make more power than a 340.
Re: Need advice 340 vs 360 in A body [Re: Supercuda] #137691
10/17/08 08:27 AM
10/17/08 08:27 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Beg to differ on this one. The Maggie cover is actually DEEPER than the LA. I measured both when I was swapping Magnum accessories on to my 340, and I wanted to leave the fuel pump eccentric on my cam. Worked just fine.
What DIDN'T work were the Maggie accessories. The LA blocks don't have the bosses that the Maggies do to mount the PS pump and tensioner, so you have to do a bit of fabrication to make them work. I won't likely do Maggie parts on an LA block again. It's just too easy to start with a Maggie block. I suspect, but can't prove, that LA accessories work just fine on a Maggie, once the TC/WP is swapped out.
Clair
Re: Need advice 340 vs 360 in A body [Re: 70AARcuda] #137692
10/17/08 08:37 AM
10/17/08 08:37 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
The piston weight is irrelevent as far as rpm goes. Both weight about the same. The internal kinematics is what counts here. Our stock weight 340s approach 8,000rpm and the same 360's are done at 6,500max.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
