Re: My 440 EFI- Coil on Plug & LS PCM ignition project
[Re: 71_340s_Only]
#1376744
04/16/13 10:55 AM
04/16/13 10:55 AM
Posts: 485 Raleigh, NC
j.mcconnell
Raleigh, NC
Not to hijack, but I've been doing some research as well. It seems Microsquirt2 v3 (with some minor mods)can run with just the 24x GM wheel and no cam sensor. It is batch-fire fuel and waste-fire spark but several people are running 700hp+ boosted engines with it. Conveniently, when wiring for waste-fire spark the cylinder pairs are the same for an LS1 and small block mopar. It looks very simple to install and you can still use junkyard LS1 coils, throttle body, etc. I plan to install a 24x wheel like Quicksilver did and follow these directions: http://www.yellowbullet.com/forum/showthread.php?t=543066This seems like a simple option for those looking to tune their own car. Its about $350-400 for the microsquirt, so cost will probably end up about the same as using the GM computer and paying for the tune.
[Re: gpuller]
#1376747
06/25/13 01:14 PM
06/25/13 01:14 PM
Posts: 235 Tucson AZ.
RADAMX
Tucson AZ.
I did the EFI with coils about 10 years ago with a AEM ecm and LS coils . It is nice to be able to tune fuel and timeing on a individual cylinder. I run 400 hp nitrous . But with out EGTs or 8 O2s I am not sure I would bother as it is going to be a tunning nightmare . I have 8 EGTs and 2 O2s .would like 8 O2s but that is cost prohibitive. We are running the Factory Ls computers on some stuff and I can tell you it is good stuff . It how ever is not as good as A good aftermarket ECM . I have A lot more usable features in my AEM. the factory Ecm is dedicated where others make them much more flexable. As you can see I covered my Ls coils as they are ugly as sh!t ![](http://memimage.cardomain.com/ride_images/1/2686/4461/6714730090_medium.jpg)
[Re: PC-CHARGER]
#1376751
12/02/13 07:32 PM
12/02/13 07:32 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I plan on using a Jeep cam sensor like the one you have mentioned in this thread. The pinout shows a 5V in, GND and 0-5V output. I assume that one would have to regulate the 12V battery voltage down to 5V for this sensor?
Regulated 5V is provided by the FAST ECU at the TPS and MAP sensors (red wires).
[Re: Dos Snails]
#1802521
04/13/15 05:49 PM
04/13/15 05:49 PM
Posts: 20 Easton, Minnesota
gpuller
Easton, Minnesota
I still need a bushing to use the Jeep Dizzy, Any one have anything? SD Concepts is making them.
[Re: gpuller]
#1803142
04/14/15 12:09 PM
04/14/15 12:09 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I still need a bushing to use the Jeep Dizzy, Any one have anything? SD Concepts is making them. Yes, very nice piece well worth the asking price.
68 Barracuda Formula S 340
[Re: Quicksilver440]
#2341231
07/21/17 11:09 PM
07/21/17 11:09 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Where do you purchase the SD concepts bushing? I don't see the option on their site. Is there another option?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
#2341233
07/21/17 11:10 PM
07/21/17 11:10 PM
HOTMOPR
Oakville, Wa
Hows that for a resurrection?
#2341322
07/22/17 01:44 AM
07/22/17 01:44 AM
HOTMOPR
Oakville, Wa
#2341324
07/22/17 01:58 AM
07/22/17 01:58 AM
Bad340fish
Tulsa OK
I emailed Jerry, I don't have the address handy though. You might check out the facebook page for them.
