Page 8 of 12 1 2 6 7 8 9 10 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376684
02/10/13 12:30 AM
02/10/13 12:30 AM
hooziewhatsit Offline
Do you guys think that would work on a smallblock? I can probably chop up a stock distributor to make the bushing for a SB. It is still a 1X signal right?
There's already a SB mopar EFI distributor with a 1x hall effect signal in it. I don't know the year offhand. It would be a lot bigger, but may be easier to use.
Does anyone know if there's a version of that jeep sensor comes with an 8-toothed wheel?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: hooziewhatsit] #1376685
02/10/13 12:44 AM
02/10/13 12:44 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Does anyone have an Idea on a year? That would really speed up my swap not having to fabricate one
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376686
02/10/13 12:57 AM
02/10/13 12:57 AM
"get a TBI dizzy, NOT a Maggie (Mag has a 1-tooth wheel). TBI is a little uncommon, only from around 88-91 on 318 and 89-92 on 360 -- and only in trucks, too." Buried in this thread
The TBI has the 8 tooth wheel. If you find one of those for cheap, I may just buy it off you. I need it for my 5.0 Ford EFI swap
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376687
02/10/13 03:59 AM
02/10/13 03:59 AM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
Should work fine if you make a bushing/spacer to make the distributor the correct length. Yep...it's a 1X signal.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376688
02/10/13 11:17 AM
02/10/13 11:17 AM
Norrland, Sweden
Swedcharger67 Offline
Norrland, Sweden
I am using the MS3X in full seqencial mode on both fuel and spark
36-1 trigger wheel off the crank, and the Jeep sensor for Cam. Spark will be coil close to plug using LS2 Truck coils.
Good stuff! I'm doing the same, but not given up on fitting the cam sensor in the timing cover yet!
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Swedcharger67] #1376689
02/11/13 06:03 PM
02/11/13 06:03 PM
Central Valley, CA.
Central Valley, CA.
Hey Redmist...if you don't mind, post a pic of your cam sensor bushing/spacer adapter once your done with them.
That should help others figure out what is needed to make that work.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376690
02/12/13 08:04 PM
02/12/13 08:04 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I got it all worked up in solidworks, and programmed taken care of, I just need to clear a job off the lathe, and then I will turn a few of them.
The one pictured will require about .37 to be shaved off the bottom of the Jeep CPS shaft that keys into the pump drive. This can be done real easy with a dremel, or I might try adding that amount to the top of the adapter, but then a stock hold down may not work.
Stay tuned!
This will work for our applications, I just need to finish it up. This week for sure.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376691
02/12/13 09:02 PM
02/12/13 09:02 PM
Central Valley, CA.
Central Valley, CA.
Awesome work man... Trimming the shaft is no big deal...but either way should work.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376692
02/13/13 09:48 PM
02/13/13 09:48 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Keeping it on the first page lol I promise I will have some pictures of my harness this weekend
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376693
02/17/13 09:15 PM
02/17/13 09:15 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Whalllaaaa Peanut butter sammiches!!!!
You can ask for a 2003 Jeep Wrangler 4.0 "Cam Sequencer" to get the correct CPS/SHAFT DRIVE for this project.
I made two bushings, one for my project, and one for Quicksilver440.
PM Me your Address, and I will send yours out. The O-Ring groove is a little rough, but will work, and the bushing is a .001 slip fit to the CPS, so I hope the CPS's Tolerances are good!! Haha!
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376694
02/17/13 09:33 PM
02/17/13 09:33 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Hi,
I would really like to get hold of a bushing, but I am in UK. If you dont mind posting to England, thats great, naturally I would pay for any pacjing, postae costs.
Is there anyway you could share your drg with me & I then could get one made at my local machine shop.
Thanks,
Mark . . .
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: mopar_mark] #1376695
02/18/13 12:20 AM
02/18/13 12:20 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Could you make me one for a smallblock?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376696
02/18/13 01:50 AM
02/18/13 01:50 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Making it is not a problem... finding machine time to make it is...
I have 1200 Receiver extensions for AR Style rifles that need to be made first. When that is done, I may hammer out a few more of these things.
lets see how work goes!!
As far as sharing files and prints, I am bound by my work contract to not do that. People in the defense industry frown on shared documents no matter what it is.
It's a super simple part though, if you have a caliper, and both parts, it would be easy for any machine shop to make.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376697
02/18/13 03:45 AM
02/18/13 03:45 AM
Central Valley, CA.
Central Valley, CA.
Awesome work!! That made my day....
Looks great....I like this Jeep reluctor way better than my original prototype as it's smaller and doesn't require a new cap, etc. Just looks more finished...
I've been working on the simplified standalone wiring diagram a little....gotta get back on it. Been working on Honey-dos last 2 weekends....
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376698
02/18/13 06:54 AM
02/18/13 06:54 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
No problem, I will measure & create my own sketch, was just looking to save some time.
Thanks,
Mark
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: mopar_mark] #1376699
02/18/13 02:36 PM
02/18/13 02:36 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Note to self...before starting a project like this, price tuners before hand. Local shop wants $550+ for dyno tune to go to speed density, handheld tuner cost $499 + $50 each for some credit thing I can't understand. I think I may just ditch the GM computer and go with megasquirt so I can tune it myself for free
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376700
02/18/13 03:16 PM
02/18/13 03:16 PM
Central Valley, CA.
Central Valley, CA.
I'd bet that included chassis dyno time during tuning....remember, you gotta compare apples to apples. My brothers shop I believe charges $299 ( CAL-SPEED & PERFORMANCE ) for a chassis dyno tune for an LSX based motor. Plus $100 extra for the Speed Density. It will cost you that much money for chassis dyno time even with Megasquirt.
Plus Megasquirt III is $645 for a built PCM...for $35 you can buy an LS 411 PCM (that's what I paid)+for $500 you can just buy the HP Tuners software (I've seen it for $250-$300 used) and tune it all yourself. So, it's still cheaper than Megasquirt (not that there's anything wrong with megasquirt)
Or for $35 for a LS1 PCM + $299-$400 for a MAF based tune by a tuner on a chassis dyno you don't even have to know how to tune and will be up an running.
Lot's of options...nothing wrong with Megasquirt though...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376701
02/18/13 03:20 PM
02/18/13 03:20 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
you can buy the whole holley kit (part# 550-605) for $1500 and it comes with everything you need?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: prochargedhemi] #1376702
02/18/13 06:16 PM
02/18/13 06:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And one more time from a guy who's worked on allot of Fuel Injection... My vote is a OE PCM because they have diagnostic capabilities including freeze frame PID recording & trouble codes.. With aftermarket systems you need your laptop hooked up & you need to be viewing the proper parameters if & when something goes wrong... Hard faults are easy, intermittents can be challenging but if you've go an OE PCM it will detect a fault, set a code & record the data just prior to, during & after the event....
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: prochargedhemi] #1376703
02/18/13 06:31 PM
02/18/13 06:31 PM
Central Valley, CA.
Central Valley, CA.
That's not a bad way to go (but it isn't a totally complete system...as that's basically a PCM, software and harness)....still $1000 more than using an LS PCM and buying the tuning software. But you could use that setup with the 24X crank reluctor and 1X cam signal and would have a great system...but you still would be up in the $2000-2500 range min. depending on what kind of horsepower you are trying to support.
Also...the LS PCM will do pretty much anything you need to do.
So $550 or $1500...kinds blows the low buck part out of the water. So $800 minimum for a LS based system....or $2000 minimum for a Holley system.
