Page 6 of 12 1 2 4 5 6 7 8 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: gregsdart] #1376644
01/30/13 10:30 PM
01/30/13 10:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
One thing I've always found very attractive about using an OE PCM is the fact they have the ability to store trouble codes & freeze frame data.. If something is wrong you know where to look, no aftermarket PCM that I'm aware of has that capability... The GM LS PCM has the ability to control the transmission, fans, traction control, boost control... All can be switched on or off within the program.... GM gave the programmer the ability to control everything from a mild daily driver to a very serious race package.... To bad Chrysler doesn't do stuff like that...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: gregsdart] #1376645
01/30/13 10:53 PM
01/30/13 10:53 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Any chance this setup would work with stock Gen III Hemi dual plug coils? I am looking at two Edelbrock 500 cfm carbs and the MSD controller currently, at a cost of about $1300. It would be nice to save some $$ and get a good tuneable EFI!
Mopar Action did an article a couple of issues back about a guy that sells a kit to LS a Gen III Hemi, I think it was around the $1300 mark going by memory
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: topbrent] #1376646
01/30/13 10:58 PM
01/30/13 10:58 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Rich Nedbal of Mopar Engines West / http://www.fastmanefi.com/ does some neat EFI work. Although not based around the GM PCM, his FAST XFI setup does illustrate some very clean work to use as an idea.
M1 intake with LS2/LS7 shorty style injectors
Supercool .....But really way off track in regards to budget and do it yourselfedness (Sp?)
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: gregsdart] #1376647
01/31/13 02:41 AM
01/31/13 02:41 AM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
I don't know Greg.....let me research that a bit and see if I can figure it out for you. Unless someone knows? The Hemitronix conversion uses GM LSX coils. I agree...it would be a whole lot nicer to have EFI for the same money...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376648
01/31/13 11:47 AM
01/31/13 11:47 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
We've been building more and more wiresets for these conversions. That's ours on the green engine bay. Who's car is that? There is another guy out in Cali as well, Pantera EFI. That is who is buiding my dualplug, dual coilpack Hemi..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: sunroofgtx] #1376649
01/31/13 02:06 PM
01/31/13 02:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Rich Nedbal, Fast Man EFI...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376650
02/01/13 12:08 AM
02/01/13 12:08 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Ok so back to the wiring....lol How are you going to feed the ECM a VSS signal from the mopar trans? Also Can I remove all the wires the used to go to the chevy trans? BTW I traded for a 24x/1x harness so I don't have to reengineer the cam signal problem
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: gregsdart] #1376651
02/01/13 02:33 AM
02/01/13 02:33 AM
Central Valley, CA.
Central Valley, CA.
Greg,
I looked into that a little more...and I "think" this may make it doable:
http://www.diyautotune.com/tech_articles/quadspark/using_the_quadspark.htm
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376652
02/01/13 09:48 AM
02/01/13 09:48 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
I know the older dodge ramcharger trucks has a vss that screwed on to the speedo gear, and then one off the rearend housing
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376653
02/01/13 11:32 AM
02/01/13 11:32 AM
Central Valley, CA.
Central Valley, CA.
You have two options with the VSS, use a mechanical to electronic adapter that screws on the speedo drive at the trans from somewhere like Dakota Digital. OR.....what most people do is just turn off the VSS in the PCM with your tuning software and remove those wires from the harness. Then you just use a manual transmission base tune so that the PCM isn't trying to talk to the transmission and remove all the transmission wiring from the harness as well. This is the prefered option in my opinion.
When I get time I will write up a whole wiring post covering all the wiring part of this swap, including everything that should be removed from a stock harness and a pinout chart too.
I truely think the 24x/1x reluctors with a 411 is the easiest way to go too.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376654
02/01/13 01:19 PM
02/01/13 01:19 PM
North America
K
kwikblownhemi Offline
K
North America
If you plan to allow the ECM to control idle, especially with an automatic transmission, it is best to run the vss.
Using the manual trans tune will allow for the elimination of the PRND selector signal.
Too bad Mopar didn't make their ECMs HPTuners friendly. It rocks.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376655
02/01/13 02:39 PM
02/01/13 02:39 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Would this work for that?
http://www.summitracing.com/parts/sum-g2887-1
Edit: it does appear that DD sells them cheaper than summit.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: hooziewhatsit] #1376656
02/01/13 02:51 PM
02/01/13 02:51 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You can use most any stock or aftermarket VSS with the GM PCM, in the program you can select the number of pulses per revolution so whether it's a 4 pulse or a 32 pulse you just toggle the appropriate box...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376657
02/01/13 04:37 PM
02/01/13 04:37 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Any chance this GM PCM can be tricked into controlling a Mopar OD trans?
Kevin
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376658
02/01/13 05:46 PM
02/01/13 05:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Probably...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376659
02/03/13 02:28 PM
02/03/13 02:28 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
BTT I've almost got my harness completed just have to decide on which fuse block I want to run. I'll try to post some pics soon.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376660
02/03/13 05:31 PM
02/03/13 05:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Have a look at this, configurable design, suprisingly affordable.. Order extra crimp on terminals so you can have a practice run..
http://www.cooperindustries.com/content/...S_Tns_15300.pdf
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376661
02/03/13 06:25 PM
02/03/13 06:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Kevin
I assume you are talking about lockup and shifting OD ?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: JohnRR] #1376662
02/04/13 02:08 AM
02/04/13 02:08 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
Another question....how do you setup the injectors and ignition since the LS has a different firing order than chrysler?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: SLOW67] #1376663
02/04/13 03:01 AM
02/04/13 03:01 AM
Central Valley, CA.
Central Valley, CA.
Just swap injector and coil pins 2&3 and 7&4 at the pcm connector. And then in your tuning software, assign the proper firing order in the injector bank tables so the PCM can properly report codes/misfires, etc.
