Page 5 of 12 1 2 3 4 5 6 7 11 12
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376624
01/29/13 06:16 PM
01/29/13 06:16 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Also, remember when doing injector size calculation that LS motors run fuel pressure at 58 psi.
Flexfuel injectors are actually larger...flow more lbs (like 34lbs vs. 27 lbs +/-)....than the regular fuel injectors to allow for the E-85. Unless you WAY oversize an injector, it won't affect idle, etc. much, if at all if tuned correctly.
Larger than the 42 lb ones you are using? Should make for a cheap junkyard solution if you needed more than 42 lb ones on just gas?
Kevin
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: furious70] #1376625
01/29/13 06:16 PM
01/29/13 06:16 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
FWIW I'm using an rpm perf for my turbo 383 and the distribution is beautiful according to my plugs. I use a sheet metal elbow and 5.0 TB. I have a friend who has also had the best luck with distribution and mpg with a DP on his turbo 340. My take away is use whatever intake you would use based on the goals for the car with a carb and not sweat the efi. Other people may have had a different experience.
I really have no experience to refute that experience with....so I don't know. I think all the stock high performance type intakes all tend to have long somewhat equal length runners...but most TBI style intakes tend to be more of a dual plane style...and vacume signal doesn't apply there...so it must work.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Twostick] #1376626
01/29/13 06:21 PM
01/29/13 06:21 PM
Central Valley, CA.
Central Valley, CA.
Kevin
Not larger than the 42's....but larger than the typical pickup injectors. I just guessed the lbs for the 34 lb vs 27 lbs thing....every size motor is different....but flexfuel injectors are bigger. It would be interesting to see what a 6.0 flexfuel flows (if they make such a beast...I don't know). I know my 2001 Suburban 3/4 ton 6.0L is not flexfuel.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376627
01/29/13 07:10 PM
01/29/13 07:10 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Check out the Ford cam sensor from a '90s OHC motor. It's simple.
R.
Exactly what I was gonna mention, you need to plug the distributor hole anyway, the Ford design does that pretty cleanly...
Is that off of the 4.6 SOHC?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: WO23Coronet] #1376628
01/29/13 08:03 PM
01/29/13 08:03 PM
dogdays Offline
dogdays  Offline
Well, my experience is with the SHO motor and the cam sensor just runs off the end of a camshaft. It is just a short cup that rotates, half of the cup's wall is cut away and the sensor goes over the end of the cup, kind of like a Mallory Opti-spark. As the cup rotates, either there is a cup wall in the sensor gap or there isn't.
I'm sure the one pictured is from a pushrod engine with a camshaft, and it plugs into the place where the distributor would go. That's even more applicable to a 440, as it's kind of congested at the front camshaft end.
R.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: WO23Coronet] #1376629
01/29/13 08:26 PM
01/29/13 08:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
R.
No, the 4.6 is a later design & a cam sensor was in the original design..
The 5.0 Explorer used coil packs & would be a good V8 part donor...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376630
01/30/13 12:37 AM
01/30/13 12:37 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I plan to build a body that plugs the distributor hole, uses the stock shaft/drive gear, and accepts a Jeep CPS. i will just have to cut down the stock shaft at the top. The rest should be super simple. Perhaps use some good bearings in the system instead of bushings.
It looks easy to make on the lathe/Mill, and would look much better than a converted distributor on these conversions.
When I get to that stage, I will post pics. Op good tech! I may start my own thread on my conversion, but will wait till you get farther in yours so as not to detract from each others tech!
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: redmist] #1376631
01/30/13 12:43 AM
01/30/13 12:43 AM
Central Valley, CA.
Central Valley, CA.
I had ideas of doing the same thing using this as the body.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376632
01/30/13 07:44 AM
01/30/13 07:44 AM
Utah
topbrent Offline
topbrent  Offline
Utah
FYI: You can have your existing injectors resized by Fuel Injector Connection if you need more flow.
http://fuelinjectorconnection.com/shop/viewcategory.php?groupid=118
Here are some of the higher flow stock injectors:
- The supercharged 6.2L LS9 and LSA engines injectors are reportedly 56-59-lb/hr @ 58PSI, part number: 0280158187.
- The Cadillac Escalade 6.2L FlexFuel L9H & L94 engines use 54-lb/hr at 58 psi injectors, part number 12609749, (possibly 42lb...)
- The 6.0L L96 FlexFuel engine uses a 40-42lb/hr injector part number 12587269.
Info:
http://ls1tech.com/forums/fueling-injection/1571836-lsx-family-injector-flow-rate.html
http://www.tbssowners.com/forums/showthread.php?t=85647
http://www.performancetrucks.net/forums/gmt-900-trucks-188/what-size-injectors-6-2l-510832/page2/
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376633
01/30/13 08:39 AM
01/30/13 08:39 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Does anyone have a pictures of a 411 LS1 PCM.
I believe I have one out of a 99 silverado that had a 4.8
Unfortunately there is no tag on it anymore.
Is it supposed to have 2 or 4 connectors?
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: MPerry] #1376634
01/30/13 09:07 AM
01/30/13 09:07 AM
Utah
topbrent Offline
topbrent  Offline
Utah
I believe the 12200411 pcm uses two 80-pin connectors.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: topbrent] #1376635
01/30/13 09:59 AM
01/30/13 09:59 AM
Central Valley, CA.
Central Valley, CA.
That's correct...2 plugs and a '99 4.8 would be a 411 PCM.
And thanks for the injector part numbers....good info!
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376636
01/30/13 12:03 PM
01/30/13 12:03 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
R.
I thought the same thing when I pulled this while rebuiling a ford 3.0 at work. It even has the same hex drive for the oil pump shaft. Hall effect w/2 pin plug, 5.030" OD shaft.....Might be easier/cleaner to mod one of these than fab something from scratch. Ford 5.0/4.0 and 3.0 pushrod motors all used them.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Bill MeLater] #1376637
01/30/13 12:05 PM
01/30/13 12:05 PM
Wisconsin USA
Wisconsin USA
'Nother
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Bill MeLater] #1376638
01/30/13 12:07 PM
01/30/13 12:07 PM
Wisconsin USA
Wisconsin USA
One more...
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: 1_WILD_RT] #1376639
01/30/13 07:11 PM
01/30/13 07:11 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Rich Nedbal of Mopar Engines West / http://www.fastmanefi.com/ does some neat EFI work. Although not based around the GM PCM, his FAST XFI setup does illustrate some very clean work to use as an idea.
M1 intake with LS2/LS7 shorty style injectors
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: topbrent] #1376640
01/30/13 09:09 PM
01/30/13 09:09 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Yes the one I have looks like that.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: topbrent] #1376641
01/30/13 09:24 PM
01/30/13 09:24 PM
Central Valley, CA.
Central Valley, CA.
very nice stuff...
Thats a superclean setup...Pulling the cam signal off an external belt drive too.
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376642
01/30/13 09:44 PM
01/30/13 09:44 PM
gregsdart Online content
gregsdart  Online Content
Any chance this setup would work with stock Gen III Hemi dual plug coils? I am looking at two Edelbrock 500 cfm carbs and the MSD controller currently, at a cost of about $1300. It would be nice to save some $$ and get a good tuneable EFI!
Re: My 440 EFI- Coil on Plug & LS PCM ignition project [Re: Quicksilver440] #1376643
01/30/13 09:49 PM
01/30/13 09:49 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
For anyone that might be wanting to do this with drive-by-wire (don't be afraid it's just technology ) I have found (maybe) a supplier that makes 4x cam sensors in a dizzy for chevy's. Now, I don't yet know if they will sell them separate from their kit they offer but if they do it would be an easy way to adapt to 4x. If they won't sell them without buying a kit I am going to venture into modifying a 1x reluctor like Quicksilver440 used into creating a 4x signal that can be picked up by the sensor.
Does anyone know if there are any production engines that use a 4x reluctor and sensor that would fit in a Chrysler dist.?
