Page 13 of 25 1 2 11 12 13 14 15 24 25
Re: Triple Black Bee [Re: OhioMopar] #1376134
02/23/14 11:10 AM
02/23/14 11:10 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
906's I believe. Hmmm. My Dremel tool is charged...
PM your address. I'll dig them out and send them if you want to use them.
Old, tired, and sometimes broke down. Me, not my car...
Re: Triple Black Bee [Re: new bee] #1376135
02/24/14 01:50 PM
02/24/14 01:50 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Victory! Followed by defeat. Got it back together, running, and moving. Then the freeze plug on the drivers side rear of the head let go. Don't know if I'll be able to remove it and replace it without pulling the head or if I will have to yank the head. If I pull the head, I may pull both and get some work done. Hmmm...
It can be done as I did it on my Super Bee without removing the head. We used one of those long clamps often used in wood working. I'm not sure what they are properly called, but there is a hand crank on one end. In a nutshell, we adjusted the clamp to be roughly the width of the head. On the non-crank side, we replaced the end piece with a bolt. Next, we lined up the crank end with the front freeze plug, and the bolt with the back freeze plug.
As we tightened up the crank, the bolt pivoted the rear freeze plug out.
To install the new plug, we replaced the bolt with a flat washer the same diameter as the plug. Tightening the hand crank pressed the new plug in.
Worked perfect.
Wow! That's a good one to remember
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Triple Black Bee [Re: 70440+6bbl] #1376136
02/24/14 02:11 PM
02/24/14 02:11 PM
Mt.Gilead, Ohio
OhioMopar Online content OP
OhioMopar  Online Content OP
Mt.Gilead, Ohio
Worked perfect.
I thought the exact same thing!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Triple Black Bee [Re: OhioMopar] #1376137
02/24/14 08:18 PM
02/24/14 08:18 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
I wish I took a picture of it. You may have to do some of your own engineering as this tool we made has been gone for over 6 years.
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: Triple Black Bee [Re: new bee] #1376138
02/24/14 10:42 PM
02/24/14 10:42 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'll figure something out to work. Knowing you did it and that I now have an idea of how, I'll get it done. Thanks again.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376139
02/25/14 08:29 PM
02/25/14 08:29 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If you're interested in a set of 906's that are done-up and ready to go, I believe I know the whereabouts...
Re: Triple Black Bee [Re: RSNOMO] #1376140
02/25/14 09:05 PM
02/25/14 09:05 PM
ME
79machocharger Offline
ME
Your car should get some attention driving around, really neat car.
Re: Triple Black Bee [Re: RSNOMO] #1376141
02/26/14 09:37 AM
02/26/14 09:37 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Oddly enough I was thinking about putting an ad up to look for that very thing...
You may be the man, sir.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: 79machocharger] #1376142
02/26/14 09:39 AM
02/26/14 09:39 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Honestly, I would love to have nice enough weather to test your theory! Lol.
Thank you.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376143
03/16/14 12:32 AM
03/16/14 12:32 AM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
So have you done anything but plan mods for the Mirada?
Re: Triple Black Bee [Re: Shoozy] #1376144
03/16/14 03:56 PM
03/16/14 03:56 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I've actually been buying tools, trying to become a contortionist, and then staring blindly at the Bee trying to figure out how to get the leaking freeze plug out. No luck so far...
I do have a new plan for the Mirada, though!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376145
03/16/14 11:37 PM
03/16/14 11:37 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
1981 Dodge D150 360 auto
Re: Triple Black Bee [Re: OhioMopar] #1376146
03/17/14 01:32 AM
03/17/14 01:32 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Stop being a baby and pull the motor, you don't see me whining about having to pull it out of the R/T
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Triple Black Bee [Re: AZ_A12_BEE] #1376147
03/17/14 10:36 AM
03/17/14 10:36 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Yeah, but you have some things I don't right now. Like a garage. Cherry picker. Air compressor. Concrete floor to work on. Some place (Arizona!) to keep the cold off you. A roof to keep the weather off you...
So the will continue!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376148
03/17/14 11:20 AM
03/17/14 11:20 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
well I have a garage(no heat) crappy air compressor,and a cherry picker, but they're three hours east of you.
Re: Triple Black Bee [Re: basketcase] #1376149
03/17/14 11:41 AM
03/17/14 11:41 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I have an offer of a garage to use. But in order to get there, I first need to put a wheel bearing in my truck and borrow a trailer. It never seems to end.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376150
03/17/14 01:00 PM
03/17/14 01:00 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
It does seem to be never ending, this next weekend I get to pull the 302 and C4 from the 37 and reseal both, I can't drive it it leaks like the Exxon Valdez
Re: Triple Black Bee [Re: AZ_A12_BEE] #1376151
03/17/14 01:43 PM
03/17/14 01:43 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'm kinda glad I'm only working on one right now. Aside from keeping the daily drivers on the road. I can still make plans for the other two!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: basketcase] #1376152
03/17/14 04:17 PM
03/17/14 04:17 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I'm actually slowly losing interest in the older stuff. Just not enough time to work on it anymore and the frustration of not being able to find a place to work on it. I'm definietly not equipped to do what needs done on the cars I have right now. We'll see how this summer turns out. But it may be time to unload and play with a newer Challenger.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376153
03/17/14 07:45 PM
03/17/14 07:45 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
may be time to thin the heard and concentrate on one old car.I know my road runner and the wife's VW are enough for me.
