Page 7 of 25 1 2 5 6 7 8 9 24 25
Re: Triple Black Bee [Re: OhioMopar] #1376014
08/02/13 11:52 AM
08/02/13 11:52 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I feel your pain. my car is still in the paint shop, and with our trip out west, no cash for the nats.
as far as the tags, go Historical, even get some '69 plates. less then $40 and you're done as long as you have the car.
1981 Dodge D150 360 auto
Re: Triple Black Bee [Re: OhioMopar] #1376015
08/02/13 12:04 PM
08/02/13 12:04 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
Keep up the good work. You can always trailer it to the nats...at least it will be there. I need to get my own butt in gear if I plan on taking the black bee. It's been out of the trailer only once since the nats last year.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: Triple Black Bee [Re: gtsuperbee] #1376016
08/02/13 03:59 PM
08/02/13 03:59 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
I think I'll make it. I hope so. Would like to get a picture next to your Bee. It would be like the polished and proper big brother next to the disheveled little bro!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Triple Black Bee [Re: OhioMopar] #1376017
08/02/13 11:12 PM
08/02/13 11:12 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
10:00 update. Clutch linkage is in and adjusted. Starter is in and tight. Found two brake leaks. One, I believe, is due to the crappy copper washers they use to seal the banjo bolt to the caliper. The other is a line. Should just need tightened. I'm 'adjusting' the u-joint straps right now, then I'll be done under the car for tonight. Yet to come: tighten water pump, install t-stat, install header gaskets and tighten, find tdc and index the distributor, clean paint off the plugs and reinstall, run the wires, and start the wiring replacement. I'm still feeling good, so I'll be at it for while...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376018
08/03/13 11:55 PM
08/03/13 11:55 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
agree on the crappy copper washer. I put a new rubber line on my truck, and it leaked. reused the old washer and leak stopped. hope you maek it, and take pleantty of pics!
Re: Triple Black Bee [Re: basketcase] #1376019
08/05/13 12:12 PM
08/05/13 12:12 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Still plugging away. It hasn't fired yet, but I'm getting closer. I took some stuff back to Summit and I'm waiting for the refund to post. Then I can buy some more 'stuff' and at least listen to it run.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376020
08/05/13 08:41 PM
08/05/13 08:41 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I've made continuous headway on the car, but it seems like for some reason the list keeps growing. The issues at the moment are some bellhousing bolts that are too long. I can see air between the block and the bell, and they won't tighten anymore. I still have to tighten a line and a bolt to stop my tiny brake fluid leak. I don't think that I will make the Nats, but I'm still plugging away. I'll be on it until I leave Friday for the show.
My boy helping. He's really looking forward to riding in it.
Wires routed. I'll clean it up before too long. But they're on.
Mounted the coil and the alternator and plumbed from the pump to the carb.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376021
08/05/13 08:57 PM
08/05/13 08:57 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
It sits too high in the front.
Now it sits better. But not level.
But too low, it needs to come back up. This would be be hard on the tires.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376022
08/05/13 09:27 PM
08/05/13 09:27 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Do you have the correct bellhousing for the clutch/flywheel combo your running? 10.50" vs 11.00" etc.
Re: Triple Black Bee [Re: crowbait] #1376023
08/05/13 11:35 PM
08/05/13 11:35 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Yes. Original bell. 11" flywheel. Original style pressure plate. The bolts have a good 1/4" between the head and the bell. They ain't moving.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376024
08/06/13 01:15 AM
08/06/13 01:15 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Fun thread. The photos remind me of thrashing on them to get them running back in the days before chalk marks were necessary on the muffler bearings.
Sheldon
Re: Triple Black Bee [Re: OhioMopar] #1376025
08/06/13 01:37 AM
08/06/13 01:37 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Take a measurement with a pin punch into the block...
You'll know the correct bolt length...
Re: Triple Black Bee [Re: RSNOMO] #1376026
08/06/13 03:51 AM
08/06/13 03:51 AM
It looks like you plan on running the heater core with those nice new heater hose nipples in the water pump housing. You are brave to test that heater core, I would just bypass it for now if I were you. It is August and all, you shouldnt need it
Re: Triple Black Bee [Re: RUNCHARGER] #1376027
08/06/13 06:31 AM
08/06/13 06:31 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Sheldon
Yep, exactly. Back when it was fun and you weren't drawn and quartered for mods to your own car. Very fun thread.
Old, tired, and sometimes broke down. Me, not my car...
Re: Triple Black Bee [Re: ] #1376028
08/06/13 09:58 AM
08/06/13 09:58 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I blasted it out with air yesterday. Had a bunch of crap in one side and blew a bunch of water out. I probably should have just stuck some pipe plugs in. There is still time.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: Shoozy] #1376029
08/06/13 10:03 AM
08/06/13 10:03 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Sheldon
I'll never be part of the chalk mark crowd. All I want to do is make 'em run and improve them. Whether that is by upgrading the drivetrain or improving the body little by little. I'll make it nice some day, but also the way I want it.
I've never been much of a conformist. That's why I liked Mopars in the first place!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: RSNOMO] #1376030
08/06/13 10:04 AM
08/06/13 10:04 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Will do. Thanks! Simple enough.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376031
08/06/13 09:12 PM
08/06/13 09:12 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Start of the wiring carnage.
All gone!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: OhioMopar] #1376032
08/06/13 09:18 PM
08/06/13 09:18 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I got the wiring almost completed today. Replaced the motor mount I broke. Wired the starter. Added a bolt I was missing to the bellhousing and pulled one that was too long out to measure. I accomplished a lot today.
I also scored an exhaust system for $50. I had it bent for a car I wrecked long ago. It was old enough the glasspacks burnt out of it. But new enough the guy who bought the car heated the connections and it came apart. It's 2&1/4" and had glasspacks on it, but it sounded pretty good behind a 383 that had an almost identical cam in it.
Progress. I might make it yet.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Triple Black Bee [Re: basketcase] #1376033
08/06/13 10:00 PM
08/06/13 10:00 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
you'll make it, it's only Tuesday!
