Re: Triple Black Bee
[Re: OhioMopar]
#1376014
08/02/13 11:52 AM
08/02/13 11:52 AM
Posts: 7,841 east side of Ohio
basketcase
east side of Ohio
I feel your pain. my car is still in the paint shop, and with our trip out west, no cash for the nats. as far as the tags, go Historical, even get some '69 plates. less then $40 and you're done as long as you have the car.
1981 Dodge D150 360 auto
[Re: OhioMopar]
#1376015
08/02/13 12:04 PM
08/02/13 12:04 PM
Posts: 2,230 restos just aren't my thing
gtsuperbee
Keep up the good work. You can always trailer it to the nats...at least it will be there. I need to get my own butt in gear if I plan on taking the black bee. It's been out of the trailer only once since the nats last year.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
[Re: OhioMopar]
#1376017
08/02/13 11:12 PM
08/02/13 11:12 PM
Posts: 8,793 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
10:00 update. Clutch linkage is in and adjusted. Starter is in and tight. Found two brake leaks. One, I believe, is due to the crappy copper washers they use to seal the banjo bolt to the caliper. The other is a line. Should just need tightened. I'm 'adjusting' the u-joint straps right now, then I'll be done under the car for tonight. Yet to come: tighten water pump, install t-stat, install header gaskets and tighten, find tdc and index the distributor, clean paint off the plugs and reinstall, run the wires, and start the wiring replacement. I'm still feeling good, so I'll be at it for while...
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
[Re: OhioMopar]
#1376018
08/03/13 11:55 PM
08/03/13 11:55 PM
basketcase
east side of Ohio
agree on the crappy copper washer. I put a new rubber line on my truck, and it leaked. reused the old washer and leak stopped. hope you maek it, and take pleantty of pics!
[Re: OhioMopar]
#1376020
08/05/13 08:41 PM
08/05/13 08:41 PM
OhioMopar
Mt.Gilead, Ohio
I've made continuous headway on the car, but it seems like for some reason the list keeps growing. The issues at the moment are some bellhousing bolts that are too long. I can see air between the block and the bell, and they won't tighten anymore. I still have to tighten a line and a bolt to stop my tiny brake fluid leak. I don't think that I will make the Nats, but I'm still plugging away. I'll be on it until I leave Friday for the show. My boy helping. He's really looking forward to riding in it. Wires routed. I'll clean it up before too long. But they're on. Mounted the coil and the alternator and plumbed from the pump to the carb.
[Re: crowbait]
#1376023
08/05/13 11:35 PM
08/05/13 11:35 PM
OhioMopar
Mt.Gilead, Ohio
Yes. Original bell. 11" flywheel. Original style pressure plate. The bolts have a good 1/4" between the head and the bell. They ain't moving.
[Re: RSNOMO]
#1376026
08/06/13 03:51 AM
08/06/13 03:51 AM
It looks like you plan on running the heater core with those nice new heater hose nipples in the water pump housing. You are brave to test that heater core, I would just bypass it for now if I were you. It is August and all, you shouldnt need it
[Re: OhioMopar]
#1376032
08/06/13 09:18 PM
08/06/13 09:18 PM
OhioMopar
Mt.Gilead, Ohio
I got the wiring almost completed today. Replaced the motor mount I broke. Wired the starter. Added a bolt I was missing to the bellhousing and pulled one that was too long out to measure. I accomplished a lot today. I also scored an exhaust system for $50. I had it bent for a car I wrecked long ago. It was old enough the glasspacks burnt out of it. But new enough the guy who bought the car heated the connections and it came apart. It's 2&1/4" and had glasspacks on it, but it sounded pretty good behind a 383 that had an almost identical cam in it. Progress. I might make it yet.
