E Body vert windshield top moulding removal #1374985
01/24/13 02:39 PM
01/24/13 02:39 PM
NJ, USA
Flying Banana Offline OP
NJ, USA
I need to remove the windshield top moulding on my '70 convertible. Screws are removed, it doesn't seem to want to budge. Any tips/pictures for damage free removal of these pieces? Manual just says "remove", but not how?
Thanks!
Re: E Body vert windshield top moulding removal [Re: Flying Banana] #1374986
01/24/13 03:02 PM
01/24/13 03:02 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
There is some foam tape between the trim & the sheetmetal, the trim rolls off from the windshield side toward the interior but the foam needs to release, in the past I've used a screwdriver in the window channel to pry up enough the the foam will begin to separate.. Just raise it a little & wait, it only takes a few minutes but if you expect it to just lift off it won't...
Re: E Body vert windshield top moulding removal [Re: Flying Banana] #1374987
01/24/13 07:09 PM
01/24/13 07:09 PM
M.A.
Fern Offline
Fern  Offline
M.A.
Mine had black adhesive that oosed from the windshield, Just pull it off slowly, use a putty knife.
Re: E Body vert windshield top moulding removal [Re: 1_WILD_RT] #1374988
01/24/13 07:43 PM
01/24/13 07:43 PM
NJ, USA
NJ, USA
That did the trick... I just needed to know what direction and what was holding it. Thanks!
