Re: Ridge Reamers
[Re: Commando1]
#1374200
01/22/13 11:47 AM
01/22/13 11:47 AM
RapidRobert
You should be able to rent one for cheap at one of your parts houses & ask them if they will but new blades in it before you walk out the door. Put a box end wrench on the center nut & pull the cutters toward you rather than pushing the blades into the cyl wall which means you need to change positions OFTEN as you go around the bore. Stop & check your work OFTEN, use WD40 & it will not cut evenly around the bore so stop when any section has ALMOST all of the ridge down flush, Just use your own judgement/patience/be conservative
Re: Ridge Reamers
[Re: MLR426]
#1374202
01/22/13 03:41 PM
01/22/13 03:41 PM
Posts: 2,530 God's Country Maryland
GODSCOUNTRY340
It's a good idea to remove the ridge before knocking the pistons from the cylinders. If you don't you can damage the ring lands in your pistons. Plus, if you leave the ridge there and install new rings, the new rings could impact the ridge when it starts, damaging the ring lands or even breaking the new rings. One thing to make sure when using a ridge reamer is to stop at the top as soon as the old ridge is gone. If you keep going you will taper the top of the cylinder and cause a head gasket leak. Make sure you follow the directions for your reamer and they'll work as intended.
Re: Ridge Reamers
[Re: Challenger 1]
#1374205
01/22/13 10:26 PM
01/22/13 10:26 PM
Ridge Reamer should be called "block screwing up machine" I have never ever seen a ring broke from "running into the ridge" just hone the thing, add some cheap rings and away you go--never a problem--do not use a ridge reamer--they are a stone age tool--just get a shop to hone the block , Wash the heck out of it and go--it will be just fine. Run the reamer, Bell out the top of the bore and you have a junker until you bore it and then many can't be saved from the massive attack done by the well meaning back yard builder ( I admire All back yard builders and have great respect for their efforts, as they usually do just fine) as long as they do not borrow a ridge reamer
Re: Ridge Reamers
[Re: ]
#1374206
01/22/13 11:17 PM
01/22/13 11:17 PM
GODSCOUNTRY340
I just fixed a 360 engine that had three pistons with the top rings of each broken because he didn't remove the ridge, did a quick hone job and threw it together. The aftermarket 12.5 pistons he used had a higher ring height and on each stroke those top rings were over-riding the ridge causing them to break. Just because you haven't seen it doesn't mean it doesn't happen. It can and does happen.
Re: Ridge Reamers
[Re: NachoRT74]
#1374209
01/23/13 09:27 AM
01/23/13 09:27 AM
Posts: 10,750 North Dakota
6PakBee
North Dakota
I have the same ridge reamer that Challenger 1 has. On a re-ring job, I've always used it. In my cases typically I am re-using the pistons so the upper ring position is the same. I'll cut until I just reach the end of the ridge, then stop. Where I have seen people get into trouble is they start cutting the ridge out, get in a hurry, don't watch where they are going, and end up cutting into the upper ring travel area. Then you are screwed. As to 'belling' the bore with a ridge reamer, IMHO as long as it's above the top ring travel area and you didn't get carried away (looks like a funnel), who cares?
Now something that's other than a simple re-ring, well that's another matter entirely.
Re: Ridge Reamers
[Re: Commando1]
#1374210
01/23/13 10:47 AM
01/23/13 10:47 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Use a flap wheel in a die grinder
You can do more harm than good
You should be able to rent one...Just use your own judgement/patience/be conservative
Do not use a ridge reamer
There are just too many ways to screw up a block with a ridge reamer
Any ridge that too deep to cleanup with a hone job, likely needs an overbore anyhow
SAME ONE I USED AND RUINED MY BLOCK
I've always used it
Re: Ridge Reamers
[Re: ]
#1374212
01/23/13 11:00 AM
01/23/13 11:00 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I bought a 70 440 HP block that was standard bore , some donkey went at it with a ridge reamer. I didn't find out how bad it was till time to bore it , started with .030 , one cylinder the cutter didn't even touch the cylinder in one area til about 2" down the bore , next was about 3/4" , he got better as he went along... ended having to bore it .040 , except the one cylinder that didn't clean up till .075 ... that one got a sleeve
Re: Ridge Reamers
[Re: buildanother]
#1374214
01/23/13 11:56 AM
01/23/13 11:56 AM
JohnRR
U.S.S.A.
Wow, the big problem I've seen in all these responses, is the use of pistons with higher ring location than the pistons that came out. That can't fly at all. that case NEEDED a bore job.
Re: Ridge Reamers
[Re: 6PakBee]
#1374216
01/24/13 02:08 PM
01/24/13 02:08 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
well, that was not my case... I cut until the ridge area, but I was to change pistons for stroke, so diff piston ring run ( here is where I need the brickwall icon LOL )
