Page 3 of 3 1 2 3
Re: Here we go again ! [Re: CHAPPER] #1374021
03/04/13 11:28 PM
03/04/13 11:28 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
well did't have that going on The first time around so we can rule that out. the only two things that are the same are a crack sleeve and the Distributor and I got a new one of them coming..
Re: Here we go again ! [Re: VernMotor] #1374022
03/05/13 05:10 AM
03/05/13 05:10 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
So the new machinist called said my crank is also cracked in many places. I said I told you it would be. He can't believe it .. so 1 1/2 years later same problems crack sleeve- crack crank and wrist pin bushing bad, the very same things wrong as before.I am starting to think it is all because of the crack sleeve. Water getting in to that cy and detonating .
He wonder about the balance job ? I am not sure what to think ?
You need a crank? got a good steel one.
Re: Here we go again ! [Re: dartman366] #1374023
03/05/13 01:45 PM
03/05/13 01:45 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
ok I got it under control. But don't let that crank go no where LOL
Re: Here we go again ! [Re: VernMotor] #1374024
03/05/13 01:53 PM
03/05/13 01:53 PM
tboomer Offline
tboomer  Offline
Good luck,Vern! Did you put a tranny brake in yet??
Re: Here we go again ! [Re: tboomer] #1374025
03/05/13 02:39 PM
03/05/13 02:39 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
NO I think that going on hold for a while !
Re: Here we go again ! [Re: VernMotor] #1374026
03/05/13 03:12 PM
03/05/13 03:12 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I don't plan on getting rid of it, but its here if you need it.
Re: Here we go again ! [Re: dartman366] #1374027
03/07/13 10:42 AM
03/07/13 10:42 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Damm Vern,that's enough to give mr GRAY hair,,,,,,,,,,,wait..........I already have grey hair
Very fustrating what your going through,hope the new machinist cures that problem!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 3 of 3 1 2 3
