Re: Here we go again !
[Re: VernMotor]
#1374001
01/22/13 10:37 PM
01/22/13 10:37 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Quote: "this is the first time I have had the bearing out of the rods. not so pretty. ???" I don't know if that's bad after 250-300 runs. That's alot of laps. That said, I'm no engine building professional, but I DID stay at a Holiday Inn last week. LOL ![](/ubbthreads/images/graemlins/shruggy.gif) On the rod bushing issue, I'm thinking too what the P man said: it can really be only 1 thing(my opinion) that the press fit of the bushing into the rod isnt tight enough and for some reason the pin to the bushing has more friction then the bushing to rod... the pin must have been too tight on the fit ![](/ubbthreads/images/graemlins/wave.gif)
[Re: VernMotor]
#1374006
01/22/13 11:37 PM
01/22/13 11:37 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
My opinion....everyone is WAAAAY overthinking this.....the pin fit was done wrong. My ![](/ubbthreads/images/graemlins/Twocents.gif)
RIP Monte Smith
[Re: CompWedgeEngines]
#1374007
01/22/13 11:45 PM
01/22/13 11:45 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
I agree.. just hard to believe that I let it happen two times ! ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: VernMotor]
#1374008
01/22/13 11:58 PM
01/22/13 11:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So maybe its time time change to another guy... 2 times... and the third your out.... sorry to see you have a issue... time to sleeve it again ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 572charger]
#1374009
01/23/13 12:08 AM
01/23/13 12:08 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
did u pin fit the rods ? all brand new rods need pin fitted to the piston pins u are useing , even my 1600..00 olivers needed done i put 9 tenths to a little over 1 thou depending on application ,no2 and blown/ turbo need more because they will gauld the pin to the bushing easy !!
![](/ubbthreads/images/graemlins/iagree.gif)
440Source told me right up front the pins bushings needed to be honed to fit.
Kevin
[Re: VernMotor]
#1374011
01/23/13 12:15 AM
01/23/13 12:15 AM
MR_P_BODY
No sleeve , had 6 blocks sonic checked and got a good one to start with.
![](/ubbthreads/images/graemlins/thumbs.gif) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: VernMotor]
#1374012
01/23/13 12:27 AM
01/23/13 12:27 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Time to pay your dues to the guy upstairs to stop the hating, that may change your "luck" ![](/ubbthreads/images/graemlins/whistling.gif) Just kidding ![](/ubbthreads/images/graemlins/grin.gif) Vern, I sincerely hope it gets better for you and yours ![](/ubbthreads/images/graemlins/thumbs.gif) I've seen black spots on the back of the rod bearings and in the rod where the bearing sits caused by detonation ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Mainly lack of fuel delivery the last three hundred in the 1/4 mile ![](/ubbthreads/images/graemlins/shruggy.gif)
#1374014
01/23/13 10:12 AM
01/23/13 10:12 AM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I absolutely agree with Todd on this. I used new Ohio Crankshaft rods on my build a few years ago and took the rods and pistons to my machine shop to have them fitted. They fitted them with approx. .0003" (if I remember correctly) like they do all of their engines (mostly BB Chev). After talking to Todd, I took them back to the shop and ask them to hone them some more, to approx .0008". They didn't want to hone them that much. We settled on approx .0006". No problems so far. They felt like the bushing were being honed to "worn out". My position to the machinist was MY rods, MY bushing, MY engine, MY responsibility. This is not a Chevy. If they are worn out in a season, I'll pay you to put new bushings in then. The problem that you (Jamie) are having is exactly what Todd warned me would happen if they were too tight. Thanks again Todd! ![](/ubbthreads/images/graemlins/thumbs.gif) Getting ready to start the 3rd season on this engine. It has been freshened up (bearings, rings, valve springs, ect), rod bushings still good. ![](/ubbthreads/images/graemlins/luck.gif)
Brian Dunnigan
