aprox weight for each of the following parts??? #1371283
01/17/13 04:43 PM
01/17/13 04:43 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
440 block
400 block
pair of 906 heads
440 weiand tunnel ram intake
bryant billet crankshaft
513 bellhousing
130 tooth steel flywheel
hemi damper
double disc clutch and pressure plate
aluminum performer intake manifold for a 440
Need to figure out some shipping quotes and thought some of you might have a real good ballpark weight for each one of these parts.....thanks!
Re: aprox weight for each of the following parts??? [Re: domingo] #1371284
01/17/13 06:55 PM
01/17/13 06:55 PM
fullmetaljacket Offline
complete iron 906 heads with springs, valves, retainers, but without rocker shafts and rockers. 107 Lbs for the pair.
Re: aprox weight for each of the following parts??? [Re: fullmetaljacket] #1371285
01/17/13 07:02 PM
01/17/13 07:02 PM
sweden
sshemi Offline
sshemi  Offline
sweden
440 block 240lbs
