Dyno"d my 606, with dyno sheets
#1370494
01/15/13 10:41 PM
01/15/13 10:41 PM
Posts: 268 Mn.
daytona5812
Mn.
Hi guys. Been away for awhile. Some may remember, I had some bad luck on the dyno a few years back. I really don"t want to re-live that, so I'll bring you up to date on what I have now. It's a Mopar Perf cast block, Callies 4.75 crank, Carrilo 7.100 steel rods, Diamound 4.503 flat top pistons. Fred Brewer heads, T&D 1.75 rockers, Isky cam that comes out to 8.75 lift. Jessel belt drive, hand made sheet metal intake, two 8 yr old Pro Stock Holleys. Last year it dyno'd at 1109 hp & 810 tq. This year we made a few changes & here are the results.. 1st pull, 1128 hp at 6900 & 872 tq at 5900. Was rich with 96 jets, so went down to 94s 2nd pull, 1143 hp at 6900 & 879 tq. Droped the 15w40 Delvac oil & put in 10w30 Brad Penn 3rd pull, 1152 hp at 7000 & 880 tq. Was using C116 vp. Wanted to try 114+ 4th pull, 1149 hp at 6900 870 tq. Didn't like the fuel. So we tried some Q116 5th pull, 1147 hp & 869 tq. showed very lean. Went up to 96 jets again 6th pull, 1175 hp & 877 tq. still showed alittle lean. only had 99 jets, so we put those in. 7th pull, 1169 hp & 879 tq. The o2 was real close there, & the power curve was real smooth. So, all & all I was real happy to say the least. It runs great & I cant wait till summer comes. Hope I didn't bore you to death? thanks, Vern!!!
Re: Dyno"d my 606, kinda long
[Re: daytona5812]
#1370495
01/15/13 10:47 PM
01/15/13 10:47 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
[Re: Biginchmopar]
#1370497
01/15/13 10:59 PM
01/15/13 10:59 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
Im nowhere near your league- sounds like a ton of cubic dollars! I still enjoyed hearing your step by step dyno tune. With that much $ invested were you a-b-a ing all the changes to verify that no other factors were involved? Congrats on your sweet motor. I've built and beaten a couple 4 3/4" stroke harley motors into the ground- they last a good while (apples to oranges!) I hope yours lasts a good long while for ya. What kind of feeding does a motor like that need? Regular valvespring changes? ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: daytona5812]
#1370503
01/16/13 03:28 AM
01/16/13 03:28 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Vern sounds great and glad to see you posting it up on here. Look forward to hearing the results.
[Re: daytona5812]
#1370508
01/16/13 03:48 PM
01/16/13 03:48 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
According to other racers that have used the Q16 you do need to jet it up 4 or 5 size larger on Holley jets to make the most power ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I like to jet the motor up, on the dyno or at the track, until it slows down the MPH in the 1/4 and the go the other way until it slows down, that tells me what that motor and carb. wants on the jetting that day ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I ran into a problem on my carbs,both Dominators and 850 DP, the dang .110 needles and seats weren't big enough on straight pump gasoline ![](/ubbthreads/images/graemlins/rant.gif) What size are you using on your carb? BTW, I had a Holley 1150 CFM carb. converted to E85 and it has .150 stainless needles and seats in it ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I was able to jet it up rich on the dyno using the local pumpp E85, it tested out to be E75, not E85 ![](/ubbthreads/images/graemlins/shruggy.gif) I had to jet that carb. down three sizes on all four jets to get max power and torque.
[Re: gregsdart]
#1370513
01/17/13 11:16 PM
01/17/13 11:16 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Vern, mind posting a picture of the best dyno pull print out?
Here you go, Greg. Had Vern send them to me.
Wes
![](http://i1123.photobucket.com/albums/l547/JUZ4TWO/IMG_0001_zps9feed985.jpg)
![](http://i1123.photobucket.com/albums/l547/JUZ4TWO/IMG_0002_zpsdff4144f.jpg)
![](http://i1123.photobucket.com/albums/l547/JUZ4TWO/IMG_0003_zps6dde0188.jpg)
[Re: daytona5812]
#1370515
01/17/13 11:47 PM
01/17/13 11:47 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Nice job Wes, Thank you.. Vern!!
No prob, Vern. Gotta make Greg happy ![](/ubbthreads/images/graemlins/laugh2.gif)
