Re: Gen III Hemi, please post things to avoid,,,,,,,,,
[Re: WO23Coronet]
#1369972
03/18/13 01:40 PM
03/18/13 01:40 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Over on the LXForums, the valve seat issue has happened to a couple of guys when they were driving the car, stopped for a short time (10-20 minutes) and when they went to start it back up, all hell broke loose with a valve seat falling out. Others it happened after the engine was seriously overheated. Could if be that the valve seats don't have enough of an interfere fit, or poor maintenance? Maybe both. Something I thought it may be is from the infamous 5.7 HEMI "tick" from the pushrods being to short. Apparently the pushrods are to short and cause to much clearence in the valvetrain and make it noisy. In the opinion of others here, could this cause the valve to pound on the valve seat, causing it to work loose? I've never heard of a 6.1 HEMI dropping a valve seat and they don't have the "tick", as a matter of fact, the cure for the 5.7 is to use the 6.1 pushrods which are longer [/quote
Keep in mind that at one point the Mexico plant that was producing the engines, were capable of 500,000 a year. That's 9600 a week. Almost 2000 a day sooooo. Matt
[Re: MattW]
#1369973
03/19/13 06:23 AM
03/19/13 06:23 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Short vid of the 6.1 with Modman running in my car - The background whine is the cooling fan....but you get an idea of the idle. Ive found it very sedate on the whole.... Cam spec .566/.556 - 218/227 @ .50 - 110 LSA, 114 ICL Eddie AVS 800. http://www.youtube.com/watch?v=9cylXD4KxkY
[Re: hemidup]
#1369974
03/19/13 10:01 AM
03/19/13 10:01 AM
MattW
Ontario Canada
Thats my theory anyways. I don't think the coils can handle the extreme cylinder pressures according to what I've seen at the dyno. We added an AEM cid box, but never had the chance to get back to test my theory out since the engine is now nestled in an engine bay.
Jerry I had a brain fart.
IS it POSSIBLE to disconnect one spark plug so that more juice is going to the one? Would the coil work that way? Matt
[Re: Moparmal]
#1369975
03/19/13 11:47 AM
03/19/13 11:47 AM
Posts: 833 MN
hemidup
MN
Eddie AVS 800.
I forsee a new cam swap in the near future.
Jerry Williams.
[Re: MattW]
#1369976
03/19/13 11:53 AM
03/19/13 11:53 AM
Posts: 833 MN
hemidup
MN
No....BTW, Taking the beast to a chassis dyno. Will try adding spark dwell to see if that helps out the firing of the coils under high cylinder pressure.
Jerry Williams.
[Re: hemidup]
#1369977
03/19/13 06:10 PM
03/19/13 06:10 PM
Moparmal
Eddie AVS 800.
Care to expand on that?
[Re: Moparmal]
#1369978
03/19/13 06:33 PM
03/19/13 06:33 PM
Posts: 833 MN
hemidup
MN
It won't make the power you want in the upper rpm range that you expect.
Jerry Williams.
[Re: hemidup]
#1369979
03/19/13 06:40 PM
03/19/13 06:40 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I would have gone 112 LSA.
[Re: hemidup]
#1369980
03/19/13 08:18 PM
03/19/13 08:18 PM
MattW
Ontario Canada
So school me on coils please! The way I see it is the ECM send an electrical signal to the coil to fire. Is there a way to swap out the OEM coil for a LS truck coil? There was another tread on here stating that the 4.8 Truck coils are good for boosted up to 1500 hp? Sorry for all the questions just trying to learn. Matt
[Re: MattW]
#1369981
03/19/13 09:26 PM
03/19/13 09:26 PM
Posts: 833 MN
hemidup
MN
Hey Matt, before I go about figuring if GM coils work, I need to see how these G3 coil packs work under boost. Here's a pic of my time slips from my boosted 5184lb truck... a little fuzzy so I'll lay it out. 1.48 60' 4.36 330' 6.87@97.3311.05@113.45What's wrong with those time slips?......Alot!
Jerry Williams.
[Re: hemidup]
#1369982
03/19/13 09:57 PM
03/19/13 09:57 PM
Posts: 4,254 Canada
WO23Coronet
Canada
With a 6.87 1/8 mile et u should be running a 10.6 ish 1/4 mile, according to the Wallace calculator
[Re: WO23Coronet]
#1369983
03/19/13 10:08 PM
03/19/13 10:08 PM
Posts: 833 MN
hemidup
MN
Actually I was hoping for a 10.90. The cross sectional density plays a big part with these Ram truck's. Heck, folding in the mirrior's is good for an additional 1 mph in the 1/4.
I just need the spark to light the fire.
Jerry Williams.
[Re: hemidup]
#1369984
03/19/13 10:22 PM
03/19/13 10:22 PM
Posts: 4,254 Canada
WO23Coronet
Canada
My bad, I wasn't using Wallace, it was some other one, a cording to Wallace it says pretty much what you're hoping for, it predicts a 10.86 1/4 mile based on your 1/8 mile et, but says u should be around 122 mph ! You're at 113mph, where did 9 mph go? Is that your coils not lighting it off properly once the boost gets to high or just the pure size of the truck pushing so much wind like you said in your previous post?
[Re: hemidup]
#1369985
03/19/13 11:14 PM
03/19/13 11:14 PM
Moparmal
Do you think 460 at the crank is achievable?
Alex - went with 110 lsa to lower the tq band a little and improve overlap. The drop in vacuum wont effect the induction so bad because its not efi.
[Re: ZIPPY]
#1369986
03/19/13 11:15 PM
03/19/13 11:15 PM
Posts: 287 Michigan
SC304
Zippy,
can you shed any light on the 426 crate motor that has been listed in the NHRA classification guide?
Anyone?
I'm looking to verify which block part number is used with the new Apache heads? does it have the typical Drag Pak intake?
Great thread guys keep it up. lots of good info contained here.
Mike
[Re: Moparmal]
#1369987
03/19/13 11:51 PM
03/19/13 11:51 PM
AlexP
Houston, Tx
That's the the thing, you don't need to lower lsa that much. That's still a tiny cam, it's just big for a stock shortblock.
I would have stayed 112 to gain back some top end. You won't be lacking any bottom end at all. A 6.1 is going to be beastly in a light car.
[Re: AlexP]
#1369988
03/20/13 01:34 AM
03/20/13 01:34 AM
Moparmal
Godbalt proved that Single plane intake responds better to a tighter lsa at lower ranges than to a wider lsa at the top end.
IOW...the gains at the bottom end running a tighter lsa outweigh the gains to be had at the top end running a wider lsa.
Still, I take your point on not needing huge slabs of torque......
I suspect the farm wont be resting on the outcome anyhow....but it'd make a fascinating comparison if I could get ahold of a normal SRTMAX cam.....
[Re: Moparmal]
#1369989
03/20/13 01:37 AM
03/20/13 01:37 AM
Moparmal
[Re: Moparmal]
#1369990
03/20/13 10:29 AM
03/20/13 10:29 AM
AlexP
Houston, Tx
I'm going to end up with a 223/227 112 with .610 lift through a 1.65 rocker. Stock 6.1 block with ported eagle heads and a custom gasket.
I'd be happy with 450rwhp through a 23 spline. A similar combo went 11.15 at 119 in a 4000 lb magnum with driver. Sub 3500 lbs with driver like my car will be more than enough.
[Re: Moparmal]
#1369991
03/20/13 11:52 AM
03/20/13 11:52 AM
Posts: 833 MN
hemidup
MN
If I was a betting man, I'd bet you'd see close to 500.
Jerry Williams.
