Offset Roller Lifters for B1 Heads #1369486
01/14/13 04:34 PM
01/14/13 04:34 PM
Colorado
506RR Offline OP
506RR  Offline OP
Colorado
Have a set of B1 Original Heads, and was wondering if my Comp 829-16 lifters will work?
I have heard people mention using offset lifters for better pushrod angles.
How much offset would I need? What lifters are recommended?
Re: Offset Roller Lifters for B1 Heads [Re: 506RR] #1369487
01/14/13 04:50 PM
01/14/13 04:50 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I've run the same lifters and B1 Original Heads as you have for 4 years no off set I don't spin it to 8,500 just 7,500
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Offset Roller Lifters for B1 Heads [Re: JD Dart] #1369488
01/15/13 01:43 PM
01/15/13 01:43 PM
SD USA
neonic Offline
neonic  Offline
SD USA
I run comp 892 lifers with the .210 offset gives a lot more pushrod clearance. But we also oil through the pushrods.
