Upper Shock Mount Support #1369036
01/13/13 05:08 PM
01/13/13 05:08 PM
U.S.
moparniac Offline OP
U.S.
Since I am ditching the t bars right now would be ok to just cut a slice thru the inner fender and weld a 1/8" plate to the upper mount and just to the snout bar and be good enough support...
generic pic
Mopar Performance
Re: Upper Shock Mount Support [Re: moparniac] #1369037
01/13/13 05:27 PM
01/13/13 05:27 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i didn't want the bars in the engine compartment and although an ebody you get the idea
Re: Upper Shock Mount Support [Re: moparniac] #1369038
01/13/13 08:16 PM
01/13/13 08:16 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Take a look at how Purple Haze from over on FABO reinforced his shockmount area.
http://www.forabodiesonly.com/mopar/showthread.php?t=180380
two 2" X 1/4" plates on each side of the shock tower and connect them to my snout bars. Then burn in a 1/4" plate on top of the towers attached to the plates,
Re: Upper Shock Mount Support [Re: topbrent] #1369039
01/13/13 09:01 PM
01/13/13 09:01 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
here's another shot that ties into the cage.
Re: Upper Shock Mount Support [Re: Deepockets] #1369040
01/14/13 06:21 AM
01/14/13 06:21 AM
U.S.
U.S.
thx for the pics! topbrent my bar is tighter to inner fender but may be able to do that just gotta worry about dr. side as those propart 2 1/8" is close in that area and how you gotta swing them into the car also which was why I was thinking high side of bar maybe.. gives me some more things to think about also...
Mopar Performance
