HEMI solit roller reliability?
#1368576
01/12/13 08:45 PM
01/12/13 08:45 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
I have read "horror stories" about solid roller lifters coming apart, bronze gears wearing out and etc. on solid rollers used on the street. I have a STREET car with a 540" HEMI with a solid roller cam and would like some opinions. Here is my set up: Solid bronze bushed lifter bores with NO oil holes, .248/.254 @ .050 tight lash (.016/.018) Street cam. The springs are 953-16 listed at 148lb on the seat and 456lb @ .650 lift, (My net lift is .588/.573). The engine obviously is low rpm, (5,900 max HP) and has a 6,000 rpm chip. On a trip, the tack stays below 3,000 rpm at highway speed. Of course it has a bronze gear. I use 10/30 Valvaline race synthetic and cold oil pressure is 80lb. while hot cruise is 60lb. Hot idle is 30lb. My qestion is: do I have to worry about driving the car 200+ miles one way to a cruise in? Are the lifters/bronze gear subject to destroy my engine without warning? Or are the horror stories limited to 7500+ rpm, .800 lift engines that are driven on the street? I know that this section deals mostly with "race" comboes, but I think you guys have far more experiance with solid rollers than do the "restoration" guys. Thanks in advance for your experiance/advice. Oh, I have 1,100 trouble free miles on the engine with one valve check/adjust at 500 miles with no adjustment, metal shavings, or obvious wear noted.
Re: HEMI solit roller reliability?
[Re: Hemi ragtop]
#1368581
01/15/13 11:24 AM
01/15/13 11:24 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
If you have good parts and the cam isn't very aggressive, you'll be fine. My block has no lifter oil galleys. There's plenty of oil from splash and drainback to lube the lifters. Been running the same block/cam/lifters since 2006 w/ no issues on the street and strip. I use Isky Red Zone lifters.
