Re: 904 trans banging full throttle 1-2 upshift??
[Re: tpabayflyer]
#136832
10/15/08 08:50 PM
10/15/08 08:50 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my experiance is 5.0 don't work too well in a 904 I would use a 3.8 or 4.2
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Evil Spirit]
#136835
10/18/08 09:12 AM
10/18/08 09:12 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Hardly an expert but know enough to be dangerous.
If his VB has low band apply and there is black sediment is there too much overlap in 1-2??? If thats the case the 5.0 lever would apply slower and limit the apply.
Could the low-rev band been too tight??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: tpabayflyer]
#136837
10/18/08 03:45 PM
10/18/08 03:45 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the "momentarily dis-engaging" happens on a manual 1-2 upshift it's probably a case of severe overlap; on a manual upshift the rear band is slow to disengage and the trans is momentarily "in two gears" at once.
[Re: John_Kunkel]
#136838
10/18/08 03:53 PM
10/18/08 03:53 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
If the "momentarily dis-engaging" happens on a manual 1-2 upshift it's probably a case of severe overlap; on a manual upshift the rear band is slow to disengage and the trans is momentarily "in two gears" at once. [/quoteExactly was I was thinking,I have in the past used a spring from a t-35 trans and install it in the rear band...works great and no over lap.
[Re: CJK440]
#136839
10/19/08 10:50 AM
10/19/08 10:50 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
the 5.0 applys a little faster and has more leverage to hold the drum , but it releases slower .
[Re: tpabayflyer]
#136842
10/20/08 08:28 AM
10/20/08 08:28 AM
JohnRR
U.S.S.A.
Well, today while driving the car the trans finally let go... 1-2 shift let out a nice big bang and that was all she wrote.... no forward gears or reverse..... but PARK still works
O.K. now what... do I look for a small block 727 to build or do I try and fix this 904 (999)??????? I do like having the 2.74 low gear but maybe I should just settle for the 727 and get a higher stqall converter??? TBF
No forward tells me something inside the trans broke ( obviously ) , but no reverse ? it's either a broken input shaft , the splines on the front of the output shaft or the pump , drop the pan and see whats in there ...
