Page 3 of 3 1 2 3
Re: realistic et goal for a 78 400 [Re: MPerry] #1367658
01/14/13 12:35 PM
01/14/13 12:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
you need more
gear but use what you have...
I have another 3rd member with 4.30's on a strange spool if you think that is better.
Set your gear ratio and tire size to determine your
trap rpm and set the conv to get your 60'(make sure
you figure the conv slippage in with the trap rpm)
Re: realistic et goal for a 78 400 [Re: MR_P_BODY] #1367659
01/14/13 12:42 PM
01/14/13 12:42 PM
Fitchburg,Massachusetts
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
(make sure
You just lost me!
Re: realistic et goal for a 78 400 [Re: MR_P_BODY] #1367660
01/14/13 12:51 PM
01/14/13 12:51 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Car originally had 26" tires a 4.30 gear lines up to 7000rpm at 125mph
3.91's with 26" 7000 at 133mph
28" 4.30 7000 at 135
28" 3.91 7000 at 150
Re: realistic et goal for a 78 400 [Re: MPerry] #1367661
01/14/13 12:59 PM
01/14/13 12:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
(make sure
You just lost me!
Just for a number lets say the conv has 10% slippage
you need to figure that 10% into the trap rpm if
you want a real trap rpm
Re: realistic et goal for a 78 400 [Re: MR_P_BODY] #1367662
01/14/13 01:03 PM
01/14/13 01:03 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
how does one figure out converter slippage?
Re: realistic et goal for a 78 400 [Re: gregsdart] #1367663
01/14/13 02:12 PM
01/14/13 02:12 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
I am not sure how well they will fit, but QUICKD100 had great success with a pair of Thermoquads on a Tunnelram Hemi. Might be a cheap alternative, and once dialed in, ought to run like scat!!! I am betting two tenths quicker than the best single plane deal.
What I like about this combo is the small preimarys for cruise, and vacuum secondary's providing as much air as the combo will need for max power.
As far as mounting, there is a way. Might need to get creative, but it can be done. I think I have two TQ to holley pattern adapters, and if you choose to try this combo, they are yours for the shipping.
A couple of swap meet carbs, two rebuild kits and some jets and you are in business.
I like that idea. I have a pair of TQ's and it seems like a cheap and cool plan.
Re: realistic et goal for a 78 400 [Re: MPerry] #1367664
01/14/13 04:18 PM
01/14/13 04:18 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
The tunnel ram.
Re: realistic et goal for a 78 400 [Re: MR_P_BODY] #1367665
01/14/13 07:21 PM
01/14/13 07:21 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Well I'm going to give it a shot & find out. 12.50 or bust!
I will be able to bracket race it either way.
do a pocket port on the heads you want to use...
thats real easy to do.... the conv will make a big
difference as well as the chassis set up... if your
looking to go 12.50 in the heat you need to make it
run 12.30 in good air and I'm sure some of these guys
are telling you the best they ran... you need more
gear but use what you have... the 509 might get close
with the porting... also do a match port to the
intake and heads... with your die grinder knock out
any chunks in the runners and just smooth up the
short turn on the heads... if you can have the heads
milled some to clean them and make them flat will
help... get the front of the car as loose as possible
so it lifts and get some rancho 9000 shocks for the
rear and I think you'll get there.... use your 850
carb
Good advice but make sure you use the 516's so you raise compression with the closed chamber heads. Use at least a 2.14 if not a 2.19 intake valve and open up the pocket accordingly.
Like he said just clean and polish the short side radius but try and open up the area a little on both sides of the valve guide boss.
Use those 4.30 gears and that thing should run great with the tunnel ram.
Re: realistic et goal for a 78 400 [Re: gregsdart] #1367666
01/14/13 08:14 PM
01/14/13 08:14 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Thats exactly what I am looking to do. I do have a pair of 450 holleys on my T-ram now, but would like to try the T-quad for the above mentioned reasons and the sheer wow factor.
How critical do you think it would be to have the same numbered carbs? SO long as the CFM is the same....or get the same numbers?
Sorry for the hijack.
Re: realistic et goal for a 78 400 [Re: NTOLERANCE] #1367667
01/14/13 08:30 PM
01/14/13 08:30 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
I don't think it will matter much as long as the carbs are close. I know I'm not going to worry too much about it.
Re: realistic et goal for a 78 400 [Re: MPerry] #1367668
01/15/13 11:36 AM
01/15/13 11:36 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike you could get a set of spacers and use that tunnel ram on the 413.
Re: realistic et goal for a 78 400 [Re: JohnRR] #1367669
01/15/13 11:42 AM
01/15/13 11:42 AM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
I never thought of that. Who makes spacers?
Re: realistic et goal for a 78 400 [Re: MPerry] #1367670
01/15/13 11:50 AM
01/15/13 11:50 AM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Never mind after a little searching I found some. Unfortunately I don't see them being cost effective at over $150 with shipping.
Re: realistic et goal for a 78 400 [Re: MPerry] #1367671
01/15/13 02:42 PM
01/15/13 02:42 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
Seems over double what you should be able to get a simple spacers for. If you want them search a little harder should be able to get spacers shipped for under $75
What was I thinking....
Re: realistic et goal for a 78 400 [Re: 72blubird] #1367672
01/15/13 04:33 PM
01/15/13 04:33 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
I'll keep my eyes open. I'm going to keep the 413 as it is and work with the 400 for now. I'll post some progress once I'm am able to escape this dungeon in a few days.
Page 3 of 3 1 2 3
