What would this combination run? smallblock
#1367068
01/09/13 07:03 PM
01/09/13 07:03 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
3200 pound A body S/S springs and good shocks( well scienced out) 904 4 inch crank 4.100 bore X block( 422) good light piston/rod combo 10.5-10.75 compression Airwolf heads good 1.875 header Roller cam, along the lines of 650 lift after deflection, 266/272 ish [Email]duration@50[/Email], tame non seat killing ramps. proper carb and intake suited to combo, probably trick 950 with super victor ported to match. Gear suited to combo and 8 inch convertor. Alternator, electric water pump and fans. Thoughts? Could that run 10 flat ish??? or would it need more head or less weight?
Re: What would this combination run? smallblock
[Re: B3422W5]
#1367069
01/09/13 07:21 PM
01/09/13 07:21 PM
Triple Threat
Renton Washington
Bottom 10's should be pretty achievable with that combo.
[Re: Triple Threat]
#1367070
01/09/13 07:25 PM
01/09/13 07:25 PM
B3422W5
Portage,michigan
I wonder if a 4.125 stroke crank and the extra inches would make better ET, or would it just be a bit more of a tractor?
[Re: Streetwize]
#1367074
01/09/13 07:40 PM
01/09/13 07:40 PM
B3422W5
Portage,michigan
I'm not sure what say a SB Eddie cc is OOTB (180 ish?) but the Airwolf looks to my semi trained eye to be approx the same size (or slightly bigger) than a BB Eddie. Don't have a side by side with an Indybrock but I doubt it's much larger.
That said it should feed a 440 ish inch small block ( however you get there) fairly well (6500 or so with the right intake). I would be tempted to run the 4.125 with a light crank, Ron Silvia's 501 revved real nice with a 264/268 Bullet HR ( I think the same grind as my 517 Big Block) and I'm not sure his heads were much better than the Airwolfs.
I think the Eddie OOTB is 177, if memory serves me right. Longer stroke yeah, like 6500 shift, 6800 trap, as opposed to 6800 shift 7100-7200 trap with a 4 incher, at least that is what i was thinking
with pump gas still gotta think if those heads are any good should make 630-640 real horespower. Might take mineshaft air or a little squirt to run 10 flat. maybe by the time i get off my butt Edelbrock will have the alternative available, but i am not holding my breath.
[Re: b1dartsport]
#1367075
01/09/13 07:45 PM
01/09/13 07:45 PM
B3422W5
Portage,michigan
With that compression I would back off on the cam duration to a limit of maybe 260/266 like the Crane cam in Dulcich's Airwolf motor thats in Engine Masters this month. I have that cam and it works really well with Indy 360-2 230 cc at about 11.00 cr. At 272/266 You would be bleeding off too much cylinder pressure. I would bet if you could get the weight down to 3000# it probably would go low 10s consistantly and break into the 9s in good air. Good luck with it,If you do plan on building it please post build and results-Randy
I had a 260/266 flat tappet cam i ran on mildly ported eddies on a 416 and it ran out of breath the last couple hundred feet, ran that same cam after swapping the top end off for ported W5's and the cam was way little(little over 11 to 1) Your right, 266 might be a hair big, but darn that 220 runner isnt much different than a W5.
[Re: cudadoug]
#1367077
01/09/13 08:40 PM
01/09/13 08:40 PM
B3422W5
Portage,michigan
Anybody have a link to that engine masters article? Or is it the same as the dyno flog Bryce posted on here with Dulchich's shortblock?
[Re: B3422W5]
#1367078
01/09/13 09:14 PM
01/09/13 09:14 PM
Posts: 982 western pennsylvania
b1dartsport
Its the same motor. The article just goes into a lot more detail with pictures ect.
[Re: b1dartsport]
#1367079
01/10/13 11:58 AM
01/10/13 11:58 AM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
I bought the pair of heads off that Engine Masters article motor for my 414. The article goes int omuch more detail about the shortblock but not really very much more (than what we have inthe Moparts thread) about the Heads. Don said his combo ran out of breath on the top end and that's pretty muc what I saw with the SDSS Stage 2's....and that was on only a maiden part-throttle shake-down launch to test the drivetrain, the Airwolfs should give me another 500 rev's of RPM Cieling which is what helped me to pull the trigger. My 414 shortblock is very close to Steve D's 408, I don't have 4 bolt caps so I'm trying to limit the motor to right at 600. My rocky was set-up with a 4.56 gear and a standard 904, I've switched to a low gear 904 and a 4.10 so I should have a good gear for either 1/8 or 1/4 now.
