Re: Painting undercarriage....over restore or not?
[Re: ScottSmith_Harms]
#1366621
01/08/13 08:09 PM
01/08/13 08:09 PM
Posts: 9,404 Texas
carcrazyguy
Texas
It was originally a /6 car so not likely to ever be worth a whole lot. I may, "may" go with late model 5.7/6.1 when the time comes. Other wise it will be a 408. It will have 4 wheel disc brakes also. So resto mod I guess would cover the build style.
The material the shop was planning to use was similar to lizard skin. He said the name of it, but I was busy looking over the body and parts. So I don't recall the exact name.
#1366624
01/08/13 08:37 PM
01/08/13 08:37 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Of course it will depend on what kind of car you are building, a restored original or a Hot Rod/Clone, etc. If it's a rarer model I'd keep it as original as possible. IMO the act of painting the bottom of the car to be all new and shiney "Jumped the Shark" a long time ago. A more factory correct look is the current trend that I see more and more these days. To me it looks even more attractive to attempt making them look as they really did. In any event I'd choose between painted and the over sprayed look of my car above, I wouldn't use any kind of Lizzard Skin or other undercoating product, it gives the look of someone trying to hide rust or other ills to most onlookers.
If you are worried about corrosion think about how you plan to drive the car. Most of these cars never see more water than the end of a hose in your driveway to wash them off occasionally, it's not likely the bottom will rot out of it if you don't coat it in some kind of bead liner/POR15/Rust shield product, especially if you do a good job of getting rid of all the rust that is there in the first place and do a proper metal prep before adding a good primer/sealer and quality paint job.
I did paint mine fully underneath and I don't regret it (yet) but I'd probably go with a more stock look if I did another. Whatever I do I will never use bedliner or anything remotely similar and would avoid undercoating as well (except for the wheelwells). I like to be able to see the metal, joints, etc. and don't like anything covering that up.
The OP's car isn't exactly a stock resto, so I'd say "fill your boots" but I'd still avoid the bedliner and similar products...just don't see the need.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1366625
01/08/13 08:59 PM
01/08/13 08:59 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Thats a hard question, but the good news is that you can do what you want and not worry about scrubbing the value of your car. It is a good idea to undercoat the wheel wells like factory to avoid chips there, but in the underneath of your car will be fine especially in West Texas. After spending many days scraping the underneath of the car, I was not about to reapply the dealership undercoating to maybe have to scrape again one day. If you don't mind the splotchy primer meathod, then go for it. I hate it but thats my preference - a completely painted surface.
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
[Re: carcrazyguy]
#1366627
01/08/13 10:08 PM
01/08/13 10:08 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
I agree with the comments on the lizard skin underside. It always seems to me that you are hiding something. I did the full paint on my first resto. It is an EW1 whte car and looks pretty sanitary underneath. The next project will be more factory correct. I plan on primer grey colored single stage urathane paint underside with color overspray like the factory.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: carcrazyguy]
#1366630
01/09/13 01:34 AM
01/09/13 01:34 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I used rock-it bed liner on my challenger. Looks like undercoating but will spray clean when washed. I know not everyone likes it, but this car will be driven daily. They like to use tar and chip on the roads here in summer also. So painting it wouldn't be a good option for me. I do like the factory look over paint. Paint looks pretty until its back on the ground and not seen much, so unless it's a show car, I see no point to it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1366634
01/09/13 02:43 PM
01/09/13 02:43 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Agree completely...
[Re: DPelletier]
#1366635
01/09/13 05:14 PM
01/09/13 05:14 PM
Silver70
Rust Belt, SW PA
Bedliner just isn't needed unless you are planning on mounting up some snow tires or going 4x4ing with your car.
I live on a partially black topped driveway. The cost would be too much to finish it to my house and it's basically mud when it rains here. So grab the hose with a nozzle when I wash it and I can spray the underside clean. I have my reasons, no need to go as extreme as snow or offroading In a few months, when the tar and chipping starts, you can't go 5 miles without having to deal with it.
[Re: Silver70]
#1366636
01/09/13 05:49 PM
01/09/13 05:49 PM
DPelletier
They don't do that tar thing here and my driveway is concrete. I don't doubt your solution works for you, my point was (and is) that 99.9% of peoples cars, given their useage, would hold up just fine with a good coat of paint.
I was mainly posting to counter the ridiculous contention by a previous poster that bedliner should be used on all cars except trailered show cars with mirrors underneath.
some people get completely carried away; many of these cars lasted for decades with nothing but a coat of primer underneath....and when they were new, most were daily drivers and not treated with any special care for the first 10 or 20 years of their life.
1974 'Cuda
[Re: DPelletier]
#1366637
01/10/13 04:13 AM
01/10/13 04:13 AM
Silver70
Rust Belt, SW PA
I understand what your saying. My cars underside was getting coated with something and I just thought the bedliner was a good choice... looks better than undercoating, good sound deadner and most of all it's easy to clean. I've yet to work on an old mopar that wasn't factory undercoated, so I can't really say on how well they hold up without it. My ram however has nothing and being in the north and in the salt, 220k later, other than some rust, it does still look nice on the underside. So maybe it is overkill using a liner. It took me maybe 20 mins to spray the car, so if nothing else, it makes me feel better about it
[Re: Silver70]
#1366638
01/10/13 08:12 AM
01/10/13 08:12 AM
Posts: 1,567 Ky
jt4406
Ky
I liked the bedliner idea to replace the factory undercoating too, but after checking with the manufacturer of the product I had (duplicolor), reading the directions on the can, and talking with a couple body men around home, all seem to indicate that it may cause recently sprayed paint to lift. Anyone sprayed it on new paint and had it cause problems with the paint coming unglued? Jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#1366641
01/10/13 03:11 PM
01/10/13 03:11 PM
Silver70
Rust Belt, SW PA
I use sem rock-it liner and never had any problems like that.
[Re: Silver70]
#1366642
01/10/13 10:54 PM
01/10/13 10:54 PM
Posts: 9,404 Texas
carcrazyguy
Texas
Thanks for all the "suggestions"! Still not sure what I am going to do. Leaning towards gray paint (primer look) with undercoating only the wheel well areas. Anyway here are some updated pics of the car.
[Re: carcrazyguy]
#1366645
01/10/13 11:22 PM
01/10/13 11:22 PM
Posts: 9,404 Texas
carcrazyguy
Texas
After looking over the pics on the computer. I just noticed the area around where the gas tank mounts. Looks like my car had the black "dip".... Maybe I should go back that way, instead of grey? Yep...VIN confirmed..."E" plant. So yes an LA built car! Black it will be!!
#1366647
01/11/13 12:56 AM
01/11/13 12:56 AM
Posts: 9,404 Texas
carcrazyguy
Texas
I will pass the info onto the painter. The Duster almost ended the career of the painter. The first day on the rotisserie the painter had rolled the car to work on the underside. He walked around to the "roof side" to get a tool. As he was walking back he walked into the trunk hinge arm. It got him right on/in his right eye! He said "luckily I had my eye closed. But as soon as I hit it, I went DOWN. I reacheed up to feel the damage and my eye was watering like it had never watered before and it was bleeding like crazy"! It turned out that he cut his upper eyelid and when got it cleaned up it was just a small cut. Made for a nice black eye though. Thankfully he is doing fine and everthing is normal now except the small war wound on the upper eye lid. He now keeps towels taped around the hinges, JUST IN CASE!!!
[Re: JMCFAN]
#1366649
01/11/13 10:26 PM
01/11/13 10:26 PM
Posts: 9,404 Texas
carcrazyguy
Texas
Whenever I am working....SAFETY GLASSES!!
Because he thought this pics was funny enough to send to me. I may have to send him a pair of those as a gift!
