Re: flex plate shield clearance help
[Re: Clanton]
#1365952
01/07/13 02:45 PM
01/07/13 02:45 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Well if you are going to run that type you will need to cut the firewall. If you dont wanna do that then go with a CSR one piece one. You will still need to massage the tunnel a bot but wont have to remove any part of the firewall.
[Re: CHAPPER]
#1365957
01/07/13 10:07 PM
01/07/13 10:07 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I have more than 1" that hits the stock firewall as marked on the tape and I cant move the engine enough down or forward to make it not hit the firewall.
Why do you NEED a flex plate shield?? I thought that was for the Chebby guys.
9.99 faster needs a shield unless you have an sfi bell.or something like that.
[Re: Clanton]
#1365960
01/07/13 11:27 PM
01/07/13 11:27 PM
Triple Threat
Renton Washington
I would personally just run the CSR shield instead of that and a blanket.
[Re: hemi-itis]
#1365962
01/08/13 12:16 AM
01/08/13 12:16 AM
Clanton
northern,Ohio,USA
Mike,I got one of those 15 years ago.Looks good on the shelf,Get the CSR sheild and be done
NO!I won't be discouraged yet.
[Re: Clanton]
#1365963
01/08/13 01:24 AM
01/08/13 01:24 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
You will have to HACK the tunnel to make it fit and you STill need a blanket.Can you return that for credit?????????
[Re: Al_Alguire]
#1365964
01/08/13 02:33 AM
01/08/13 02:33 AM
Posts: 660 San Diego
formula S
San Diego
Those shields aren't ment to be installed on a stock bodied car, they fit best on chassis cars or dragsters where they can be added to the car as part of the original build plan, you'll have to butcher the car to get it to fit
