Re: 904 Front Clutch
[Re: PC-CHARGER]
#1364514
01/05/13 02:59 AM
01/05/13 02:59 AM
dartman366
Mt. Vernon, Ohio
you can run 6 clutch's in a stock 5 clutch drum if you do like you said and juggle the thick an thin clutch's and plates, I do it with mine all the time and it works just fine,,so the answer is yes you can as long as you get the proper clearance and it sounds like you have.
