Re: What Intake Is Better Then The M-1
[Re: Sb Valiant]
#1364256
01/04/13 10:21 PM
01/04/13 10:21 PM
Posts: 2,578 sweden
1Fast340
sweden
So the victor 340's work good huh? I wonder if anyone else varify this?
i belive that it would be alot easier for most to give good recomendations if you told us more about your whole build
[Re: Sb Valiant]
#1364259
01/05/13 01:26 AM
01/05/13 01:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You have MULTIPLE things wrong for your set up..but we also need to know the RPM you turn it to... you should be up in the revs.... if you are then your headers are too small, carb is too small and its likely your cam is too small.... this is based on a W-2 head with a 2.08 valve... sure they may not be a set of maxed out heads but they should be real close to 300cfm(maybe more, maybe a little less)... and for your engine that M1 shouldnt be a bad intake... the intake isnt your choke point
[Re: MR_P_BODY]
#1364260
01/05/13 03:04 AM
01/05/13 03:04 AM
Posts: 617 PA
bwhackd34
PA
[Re: Sb Valiant]
#1364261
01/05/13 03:50 AM
01/05/13 03:50 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Instead of swapping out - your time or $ might be better spent cleaning up the M1 plenum. They are pretty diabolical in "as cast" condition....lots of sharp edges on the dividers.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
[Re: viperblue72]
#1364264
01/05/13 12:38 PM
01/05/13 12:38 PM
Posts: 143 Buenos Aires, ARGENTINA
madmax2
Did you consider using Weiand Xcelerator?
'70 Dodge GTX sb 418ci (Early A-body), Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator, Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
[Re: Sb Valiant]
#1364269
01/05/13 08:28 PM
01/05/13 08:28 PM
Posts: 6,145 Melbourne , Australia
LA360
Revving the crap out of it isn't going to make you necessarily faster. Those springs won't like past 5500-6000 if you have 3/8" stem valves. The M1 for W2 heads is water heated, it's not the best intake for a stroker, but I don't see it being too much of an hindrance on your engine. As Mike pointed out, you have a bunch of other issues with your combination that you should be worrying about.
Make a list, test at the track, Record your data.
Alan Jones
