Re: How many different 440 rods did Chrysler make?
[Re: Kern Dog]
#1363996
01/03/13 09:50 PM
01/03/13 09:50 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I have a .030 over '74 440 that threw a rod in 2004. I have been tempted to buy a single new piston and a reconditioned connecting rod and screw the motor back together. I am aware of the heavy six pack rods and their excessive mass, though I don't recall ever seeing them up close. I'm curious about the standard 4 barrel rods, since the short block I have was originally in a police car. A side note: I am a little hesistant to use any of the rods in this 440 since it seems to have been a cursed engine. Besides breaking a rod, one of the rocker shafts from this motor snapped while in yet another motor. THAT was interesting... immediate loss of oil pressure and power after 4 lifters popped out of their holes!
Unless the rods are really beat, the stock 440 rods are extremely tough. Chances are they broke from other factors (rod bolts, succumbing to detonation, rod bearing problems due to oiling issues, etc.)
There are only two rods. The six pack or heavy duty rods and the standard rods. Personally, I'm not a real fan of the 6 pack rods since they are a lot of extra weight for no real benefit. All the extra metal is in the beams. Typically the week point is in the broached area for the rod bolts. This is one of the benefits of rods that use cap screws instead of bolts.
I would have the other rods checked. If the check ok, I would replace the broken one. If more are on their way out it might be cheaper to invest in some aftermarket H beam rods. With this being a 74 engine, it probably has a cast crank so an after market rod will probably necessitate re-balancing. At that point it might also make more sense to replace the crank with a steel one.
[Re: Kern Dog]
#1363997
01/03/13 09:51 PM
01/03/13 09:51 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: torkrules]
#1363998
01/03/13 11:09 PM
01/03/13 11:09 PM
Posts: 3,916 usa
lewtot184
usa
there was a 3rd rod. i believe it came out in '63 and was for sure used in the '64 stageIII s/s wedge engines. it had more material in the rod bolt area.
[Re: lewtot184]
#1363999
01/04/13 02:50 AM
01/04/13 02:50 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
There are several more than those two, 1969 440 6 pak had its own forging number, the LY rods and some early 413/426 street wedge rods also OP, if it is a 1970 to 1975 police car 440 it probally has the later six pak style rod in it I have a bunch of OEM LY rods, some still on pistons, I'm sure I could come up with 8 good ones, you will probally need to have the crank assembly rebalanced if you switch from the heavy rods to the LY rods ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Kern Dog]
#1364001
01/04/13 02:51 PM
01/04/13 02:51 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
http://www.440source.com/stockrods.htm...I agree with John; the heavier "906" rods are stronger though the rod bolts should have been upsized. A new set of quality rod bolts gives you a decent package....as far as weight, it's a heck of a lot easier to shave the 20 or 30 grams from the piston selection. ![](/ubbthreads/images/graemlins/Twocents.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Dean_Kuzluzski]
#1364005
01/05/13 01:01 PM
01/05/13 01:01 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
.... A new set of quality rod bolts gives you a decent package....as far as weight, it's a heck of a lot easier to shave the 20 or 30 grams from the piston selection.
Not trying to start anything here..............
but once you upgrade the rodbolts and reduce piston/recip. weight wouldn't a good set of LY's do the job just fine???
I know most would question the past history, but for sake of conversation lets say you has some LY's that were NOS.
They sure would, even non NOS. MoparBilly is a testament to that , pretty sure he sprayed a set for many 100's of passes ...
#1364008
01/06/13 11:00 AM
01/06/13 11:00 AM
JohnRR
Yep, ly rods would be fine...but the 906s are still stronger. Depends what you want.
Want? With better technology the "overkill engineering" of the 6-Pack rod is excessive mass that will slow rpm's for whatever level of pumpgas motor I'd build.
Maybe if I was going to lean on it hard with nitrous they would come in handy.
I want to say that a CCJ H beam rod weighs close to the 906 rod , but they are better material and bigger bolts .
For me 906 rods are for those building trailer poodles that have to have correct original parts installed where they will NEVER be seen at a car show ... ![](/ubbthreads/images/graemlins/laugh2.gif)
