Holley carb identificarion? #1363052
01/02/13 12:21 AM
01/02/13 12:21 AM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I was up in my garage attic and found this Carb with my Superbee parts. I know it came with the car so how do I id it to make sure its the correct one?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Holley carb identificarion? [Re: TX9H6E4CUDA] #1363053
01/02/13 12:31 AM
01/02/13 12:31 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
6515 is a 1971 383 and 440 carb, for California, and Nationwide applications.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Holley carb identificarion? [Re: hemi71x] #1363054
01/02/13 01:13 AM
01/02/13 01:13 AM
minnarusta
minnarusta
Excellent this must be the original one that came with the car. Thanks for the help!!!
Re: Holley carb identificarion? [Re: TX9H6E4CUDA] #1363055
01/02/13 10:39 AM
01/02/13 10:39 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
im not thinking its an oem carb, i think its an over the counter replacement carb for the 71 383/440,
but not original to any car
the date on it is much later than 1971, it looks like a 1976 date
Re: Holley carb identificarion? [Re: TONY_DAGOSTINO] #1363056
01/05/13 02:45 PM
01/05/13 02:45 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
if you look on the underside off the throttle plate,the secondaries should be bigger than the primary side ,like a mini thermoquad. i agree the date is off.
Re: Holley carb identificarion? [Re: TX9H6E4CUDA] #1363057
01/05/13 05:11 PM
01/05/13 05:11 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
looks just like all my SHAKER N96 carbs!!!.. LIST 4737 LIST 6193 and a [non N96] LIST 6191 4 speed carb
Re: Holley carb identificarion? [Re: ph23vo] #1363058
01/05/13 10:53 PM
01/05/13 10:53 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Yes it does. Like Tony mentioned on an early post the 6515 was an over the counter replacement for those numbers. I am running one on my 71 Bee and it works flawlessly but my properly date coded 6191 is headed to Scott Harms soon and will shelve my 6515.
