rons toliet ???? #1361164
12/29/12 10:24 PM
12/29/12 10:24 PM
nc
E
earthmover Offline OP
E
nc
ok guys didn't want to hi jack the other post so here goes..... i need to get a filter for my set up and was wondering did i have to buy the 1 from killer rons are are you guys running something diff?????? i may be asking a lot of ??? on this as i am new to it.. i will be in touch with james from killer rons as well...also where is a good place to buy a test kit for the alky?????thanks guys
Re: rons toliet ???? [Re: earthmover] #1361165
12/29/12 10:31 PM
12/29/12 10:31 PM
okla.
sam64 Offline
sam64  Offline
okla.
their kits used to come with a filter,not sure if they still do.the first time in the water box was scarey,the rpm's went to the moon because i just mashed the loud pedal like it was a carb.
Re: rons toliet ???? [Re: sam64] #1361166
12/29/12 10:33 PM
12/29/12 10:33 PM
nc
E
E
nc
yea i got a set up from a member off his ride....so i have to replace the filter,mandrel,and fuel pump belt...
Re: rons toliet ???? [Re: earthmover] #1361167
12/29/12 10:34 PM
12/29/12 10:34 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I have Ron's pump with a Moroso inline filter before the pump but dont have a toilet using a Chuck Nyutten carb. Dont know if that helps or not
Re: rons toliet ???? [Re: poisondart2] #1361168
12/29/12 10:41 PM
12/29/12 10:41 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I like this filter Hilborn
Re: rons toliet ???? [Re: poisondart2] #1361169
12/29/12 10:43 PM
12/29/12 10:43 PM
nc
E
E
nc
lol thanks i guess my ??? is does most of the inline filters work with alky or is it just a select few??
Re: rons toliet ???? [Re: earthmover] #1361170
12/29/12 10:51 PM
12/29/12 10:51 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Yes as long as they can tolorate water IE not paper filters
Re: rons toliet ???? [Re: poisondart2] #1361171
12/30/12 12:11 AM
12/30/12 12:11 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
This is the filter I used. Got it from Speedway Motors. I like having a fuel shutoff at the filter.
Re: rons toliet ???? [Re: Gearhead383] #1361172
12/30/12 09:50 AM
12/30/12 09:50 AM
NC
440Jim Offline
440Jim  Offline
NC
I believe any filter with a stainless steel mesh screen (not a paper element) of the correct filter rating and flow will be fine. The filters that Ron's carry are easy to install since they have male AN ends that a normal female hose end attaches to. 2" dia filter section, S.S. basket screen.
Re: rons toliet ???? [Re: 440Jim] #1361173
12/30/12 10:01 AM
12/30/12 10:01 AM
nc
E
E
nc
that's a good point jim.. thanks
Re: rons toliet ???? [Re: 440Jim] #1361174
12/30/12 12:15 PM
12/30/12 12:15 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
Call James he'll set you up properly.
Re: rons toliet ???? [Re: evenflow] #1361175
12/30/12 01:32 PM
12/30/12 01:32 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Most important is to make sure you filter your fuel as you fill your tank. I use a jaz funnel and a system one stainless filter on the out side of the pump. If you use a pre filter make sure it is large or the pump will cavitate. Alky is a very dirty fuel.
get these from jaz:
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: rons toliet ???? [Re: 440Jim] #1361176
12/30/12 03:13 PM
12/30/12 03:13 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Yep that's the exact filter I used for years...worked great, no issues and as you and others have mentioned...James Monroe is the "man".
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
