Re: solid lifter camshaft recommendations [Re: formula S] #1360502
12/30/12 10:02 PM
12/30/12 10:02 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
When I spec'd my cam,called several cam grinders to gather info for what I wanted to do.Funny how I talked to one cam Co. several times and recieved several different opinions.
So do your homework then speak to DP.He has alot of fast & happy customers
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: solid lifter camshaft recommendations [Re: hemi-itis] #1360503
12/31/12 11:39 AM
12/31/12 11:39 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have ordered several custom cams from Dwayne Porter and he also gets my recommendation. My last solid was nitrided and used the edm lifters which I think are cheap insurance. Give him a call!
Re: solid lifter camshaft recommendations [Re: Lee446] #1360504
01/01/13 06:22 PM
01/01/13 06:22 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I,am building a motor like yours for my 1973 pro street Duster,A 1969 440 HP block,L2355 , 060 sixpack rods, sixpack crank, deep pan, true roller chain, MP 590 CAM,roller rockers,INDY EZ HEADS, INDY INTAKE,850 DP Holley,TTI headers, my Duster has 456 gears in the rear, going to run a auto trans with a 4000 stall ,motor should be a good street engine , maybe 500 HP we ran the MP 590 in a drag car years ago and it was a very good cam.good luck with your motor.
Re: solid lifter camshaft recommendations [Re: viperblue72] #1360505
01/02/13 11:54 AM
01/02/13 11:54 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
440 source stealth heads ootb
My is to spend some $$$ on going through those OOB Stealth heads to give them a good valve job, set the guide clearances, do some basic bowl porting, etc., before bothering to order a cam for it.
Better yet, send the heads to Dwayne Porter to have him do all that prep work AND have him spec & provide the cam & lifters to go with them. I know he's on the other side of the country, but UPS / FedEx makes the world a lot smaller when it comes to this sort of thing.
